Replacing G-RAID drives with bigger capacity disks.
COW Forums : RAID Set-Up
Karel Voners
on Mar 5, 2015 at 1:42:58 pm
I'm looking to change the 2 3TB drives of a 6TB G-Raid model to 2 x 4TB drives.
Does anyone know if they prevent you from doing that by designing the raid controller to only work with that specific disk capacity/disk model?
Cheers!
K.
Rainer Wirth
Re: Replacing G-RAID drives with bigger capacity disks.
on Mar 5, 2015 at 4:17:28 pm
What G-Raid are we talking about?
Normally the big manufacturers have a drive compatibility list (f.e. Sonnet or Promise).
I couldn't find one with G-Tech.
The two bay Raid is sold with 4TB and 8TB.
I would look what Discs they use and would put the same (f.e. Hitachi Ultrastar) two 4TB Discs instead of the existing 2TB models in it. To me it will work.
What are the numbers of the existing disks ? (f.e. HUA723030ALA640)
cheers
Rainer
factstory
Rainer Wirth
phone_0049-177-2156086
Mac pro 8core
Adobe,FCP,Avid
several raid systems
Karel Voners
on Mar 5, 2015 at 4:36:51 pm
Thanks for your reply.
I'm talking about the g-raid drives without removable disks. The ones with 2 drives striped together.
http://www.g-technology.com/products/g-raid-duel-drive-storage-system-8-tb
I don't think there's a drive compatibility list as they are not officially user replaceable (at least I think).
K.
Rainer Wirth
on Mar 5, 2015 at 4:41:48 pm
What drives are inside?
cheers
Rainer
factstory
Rainer Wirth
Mac pro 8core
Adobe,FCP,Avid
Karel Voners
on Mar 5, 2015 at 9:02:24 pm
I just opened one up, this drive is inside:
Hitachi Ultrastar DK7SAD300
http://www.hgst.com/tech/techlib.nsf/techdocs/EF593BD721D5D2768825782D000B8...
Can't seem to find any references to TLER or something, seems like normal consumer drives.
Thanks for the feedback!
K.
Rainer Wirth
on Mar 6, 2015 at 1:37:14 pm
The Ultrastar is a enterprise class disk.
You have got the wrong number, Ultrastars are always HUA....
cheers
Rainer
factstory
Rainer Wirth
Mac pro 8core
Adobe,FCP,Avid
Karel Voners
on Mar 6, 2015 at 1:41:53 pm
You are correct, the manual for DK7SAD300 referenced both deskstar and ultrastar.
K.
Rainer Wirth
on Mar 6, 2015 at 2:46:56 pm
Look again on the Disk
and search for a number beginning with HUA... or HDS....
HUA is Ultrastar HDS IS Deskstar
cheers
Rainer
factstory
Rainer Wirth
Mac pro 8core
Adobe,FCP,Avid
Karel Voners
on Mar 6, 2015 at 2:57:06 pm
Yes, it says DK7SAD300.
Meaning they are using consumer drives in their raid products…
K.
Rainer Wirth
on Mar 6, 2015 at 3:11:38 pm
You are right,
ist a Hitachi Deskstar its a HDS723030ALA640. I would put another 2x Deskstar 4TB HDS724040ALE640 in the enclosure. It should work.
cheers
rainer
factstory
Rainer Wirth
Mac pro 8core
Adobe,FCP,Avid
Rainer Wirth
on Mar 6, 2015 at 3:13:41 pm
But be careful and back up everything. This Raid works with Raid0, so if one drive fails all data is lost - no chance of recovery,
cheers
Rainer
factstory
Rainer Wirth
Mac pro 8core
Adobe,FCP,Avid
Rainer Wirth
on Mar 15, 2015 at 1:04:35 pm
Hi Karel,
Did it work out?
cheers
Rainer
factstory
Rainer Wirth
Mac pro 8core
Adobe,FCP,Avid
Karel Voners
on Mar 31, 2015 at 4:01:30 pm
Hi, things worked out. I replaced the drives from 2 G-RAID 6TB drives.
I used Hitachi 4TB NAS drives H3IKNAS40003272SE. Perhaps the non NAS version of that drive works as well, don't know.
I'm re-using the old 3TB drives in my server.
Cheers!
K.
