Using a OWC Helios Chassis with G-tech RAID controller: Does it work?
COW Forums : RAID Set-Up
Adam Nyholt
on Jan 30, 2014 at 9:33:45 pm
First time to post; thanks in advance for your help!
Has anyone here used the Helios thunderbolt to PCIe chassis with a G-tech RAID controller? Specifically I'm using a GSpeed ES with their controller (which I think is a rebranded RocketRaid).
Based on my research it seems like it will be compatible, but I haven't found anybody yet who has actually tried this combination. I'm also open to suggestions for other chassis if the Helios won't cut it.
Thanks! Adam.
Simon Blackledge
Re: Using a OWC Helios Chassis with G-tech RAID controller: Does it work?
on Feb 4, 2014 at 9:11:12 pm
If it is Highpoint I'd replace it going fwds.
Am sure its just a SAS HBA the ES needs yes?
Areca in the Helios I'd suggest.
The Highpoint will need a thunderbolt driver. Mosts hba's do.
s
