G-Speed Q failure - possible workaround?
COW Forums : RAID Set-Up
Todd Fletcher
on Nov 4, 2013 at 3:19:06 pm
So I have several G-Speed Q's and one stopped working this weekend. The red light flashes when I start it out and it won't mount. However all the modules are still blue lights.
I was wondering. If I up all the modules in my other G-Speed Q (maintaining same position of each drive) should I theoretically be able to access those drive again?
I plan to ask G-Speed tech support but we are an our before their support lines are open.
Thanks in advance!!
Rainer Wirth
Re: G-Speed Q failure - possible workaround?
on Nov 5, 2013 at 6:06:47 pm
Yes, if it`s exactly the same G-speed it should work. By the way, if it works, you know that it is not the drives, but some other piece of G-tech hardware. My guess is: it`s the controller. If it is the controller you can throw it away, or you persuade G-tech to get a replacement.
cheers
Rainer
factstory
Rainer Wirth
phone_0049-177-2156086
Mac pro 8core
Adobe,FCP,Avid
several raid systems
Todd Fletcher
on Nov 5, 2013 at 6:31:25 pm
UPDATE: I ran Disk Warrior on it, and it rebuilt the tables - now it works great. Much better outcome then I was fearing.
Thanks for the reply!
Rainer Wirth
on Nov 5, 2013 at 11:08:22 pm
Great,
good luck
Rainer
factstory
Rainer Wirth
Mac pro 8core
Adobe,FCP,Avid
