Drives to Update MacPro Internal Raid 1TB Drives
COW Forums : RAID Set-Up
peter tours
on May 19, 2013 at 4:25:29 pm
Could use some input on HD quality:
I want 3 of these http://www.amazon.com/gp/product/B004CSIG1G/ref=ox_sc_sfl_title_1?ie=UTF8&p...
but realistically can only afford either this
http://www.amazon.com/gp/product/B009FOFMMS/ref=ox_sc_act_title_1?ie=UTF8&p...
or this
http://www.amazon.com/Seagate-Barracuda-7200RPM-Internal-STBD2000101/dp/B00...
All comments welcome - not married to Amazon - just had these 3 in the same place. Similar prices found for each across the web.
Peter Tours
TnT Video Services, Inc.
Fort Lauderdale, FL
TRI EA5 1974-1977
Convergence ECS1B 1977-1979
Sony BVE 500 1979 - 1984
Datatron Vanguard 1984 - 1993
GVG VPE141 1993 - 1998
Media 100 1995 - 2006
Final Cut Pro 2005 to not too much longer
Adobe Creative Cloud
Eric Hansen
Re: Drives to Update MacPro Internal Raid 1TB Drives
on May 19, 2013 at 5:26:11 pm
If you're RAIDing them all together, then none of them. They're all "desktop" drives and not meant to run in RAIDs. I do have 4 Caviar Blacks in my Mac Pro, but they're older from when Blacks were part of WD's RAID offerings. I don't know what they've changed so they're no longer recommended for RAIDs. They would probably be fine, but the other 2 might have issues like spin down. This has been discussed on this forum, but my go-to are HGST Ultrastars
If you're not RAIDing them together, then those should all work fine.
e
Eric Hansen
Production Workflow Designer / Consultant / Colorist / DIT
http://www.erichansen.tv
Bob Zelin
on May 19, 2013 at 6:37:18 pm
let me make this simple Peter -
just like Eric said, these are cheap desktop drives. It sound like you are going to create a RAID inside your Mac Pro. This drive array will ultimately fail, you will ultimately lose your data, and your clients will get pissed off. I can see from your background that you have used wonderful equipment like the GVG 141 linear edit controller. You know exactly how much that cost. Things today are a tiny fraction of what they once were, but you can't expect to find the cheapest crap out there, and actually make a living out of it, without having failures. Even the best drives fail, and every drive array, even the most expensive ones require backup. By choosing the cheapest crap you can find, you are just accelerating the failure rate.
Bob Zelin
