Is There A Max Drive Capacity Limit For Mac Pro
COW Forums : RAID Set-Up
peter tours
on May 7, 2013 at 10:10:49 am
Can I put 2TB, 3TB or 4TB drives into my 2010 Mac Pro and Raid them or are they too big (for the OS? Hardware?) or is it ok? All the same of course.
Considering either of these:
http://www.newegg.com/Product/Product.aspx?Item=N82E16822149407&nm_mc=EMC-I...
http://www.newegg.com/Product/Product.aspx?Item=N82E16822178338&nm_mc=EMC-I...
Peter Tours
TnT Video Services, Inc.
Fort Lauderdale, FL
TRI EA5 1974-1977
Convergence ECS1B 1977-1979
Sony BVE 500 1979 - 1984
Datatron Vanguard 1984 - 1993
GVG VPE141 1993 - 1998
Media 100 1995 - 2006
Final Cut Pro 2005 to not too much longer
Adobe Creative Cloud
Rainer Wirth
Re: Is There A Max Drive Capacity Limit For Mac Pro
on May 7, 2013 at 10:28:03 am
Yes, you can.
cheers
Rainer
factstory
Rainer Wirth
phone_0049-177-2156086
Mac pro 8core
Adobe,FCP,Avid
several raid systems
Eric Hansen
on May 7, 2013 at 3:51:00 pm
There is a speed limit on the bus. If your goal is speed, a 4 drive RAID connected via SAS to an ATTO R680 card will be faster than the 4 internal drives RAIDed together. the internal SATA connections are 3G whereas modern drives are now 6G. Software RAIDs (using the internal bays) have a bit of processor overhead too.
if you're going to RAID, make sure you use drives designed for that. don't use "green" drives or those that spin down.
you can put drives in the optical bays too, for 6 drives internally.
if you're only going to use all these drives occasionally, i would recommend an external box that you can shut off. I have all the bays in my Mac Pro filled and it's amazing how much power this thing sucks at idle. Surfing the internet uses like 300 watts, whereas my MacBook Pro is like 20w. just another thing to keep in mind.
e
Eric Hansen
Production Workflow Designer / Consultant / Colorist / DIT
http://www.erichansen.tv
peter tours
on May 7, 2013 at 4:03:09 pm
Hey Eric thank you so much for your reply. I was remiss in not describing my rig - it's a 2010 MacPro 12 core with an Apple Raid Card and 1tb drives in each of the 4 bays. Bay 1 is the system drive, bays 2-4 are a Raid 0. So the bigger drives would replace bays 2-4 for more capacity. I am reasonably satisfied with the 250mbs throughput I get for my DVCPRO HD material. It's just that 3tb is getting to be too cramped nowadaze. I would use WD Caviar Black or similar 7200rpm drive. I was concerned over whether the jump from 3 to 6gb/s and 32 to 64mb cache would be tolerated.
Peter Tours
Fort Lauderdale, FL
TRI EA5 1974-1977
Eric Hansen
on May 7, 2013 at 4:41:25 pm
Western Digital has changed their line up a bit. they no longer recommend the Black (or what they're now calling the Black) for RAIDs. their new desktop RAID hard drive is the Red. they also have an enterprise version called the RE. but my go-to is Hitachi Ultrastar.
you'll also get a massive performance increase if you switch your boot drive to an SSD.
e
Eric Hansen
Jon Schilling
on May 7, 2013 at 4:43:01 pm
Western Digital Ultrastar Eric, Hitachi no longer makes hard drives.
Jonathan Schilling
Vertical Sales Manager
Proavio Storage by Enhance Technology Inc.
12221 Florence Ave.
Santa Fe Springs, CA 90670
Dir: 562-777-3498
Main: 562-777-3488 X106
Fax: 562-777-3499
Email: jon@proavio.com
Eric Hansen
on May 7, 2013 at 4:48:59 pm
I don't see "Ultrastar" on WD's site. is the RE the same?
all i see are HGST, subtitle "a Western Digital company". are they sticking with the HGST name or switching to WD eventually? kinda confusing.
e
Eric Hansen
peter tours
on May 7, 2013 at 5:09:16 pm
Kinda pricey then http://www.newegg.com/Product/Product.aspx?Item=N82E16822145621
I don't see an RPM for the WD Red Drives...got burned by Green, now suspicious.
I back up with an OCD passion so I think the less expensive drives might still be ok for me.
Back in the Media 100 daze I used to have 10K rpm SCSI drives...ironic ain't it?
Peter Tours
Fort Lauderdale, FL
TRI EA5 1974-1977
Eric Hansen
on May 7, 2013 at 5:17:49 pm
the Reds will be 7200.
use cheap hard drives for archive, not for RAIDs
e
Eric Hansen
peter tours
on May 7, 2013 at 5:36:04 pm
Eric - here's what bothers me about the Red drives - IntelliPower had a Green ring to it, eh? (headers would not line up)
Model # Interface Form Factor RPM Capacity Cache
WD30EFRX SATA 6 Gb/s 3.5 Inch IntelliPower 3 TB 64 MB
WD20EFRX SATA 6 Gb/s 3.5 Inch IntelliPower 2 TB 64 MB
WD10EFRX SATA 6 Gb/s 3.5 Inch IntelliPower 1 TB 64 MB
Peter Tours
Fort Lauderdale, FL
TRI EA5 1974-1977
Eric Hansen
on May 7, 2013 at 6:06:23 pm
wow, i apologize for being so wrong about the Reds. i guess i shouldn't trust what i read on a company's website.
i wonder why WD would tout an Intellipower 5400 RPM drive as their RAID drive?
still recommending the Ultrastars. been using them for years in 24/7 RAIDs with no issues. they're expensive because they're the best. 5 year warranty. HGST has a no questions asked return/replacement policy.
e
Eric Hansen
Ricardo Reyes
on May 7, 2013 at 6:16:40 pm
I'll add that the Hitachi also have a higher MTBF, there rated at 2 Million hours vs the WD RE which is 1.4 Million hours. I've worked with both drives on a daily basis and either one would do great in a RAID environment.
Ricardo Reyes
Areca Technologies - US Channel
Ricardo@ArecaUS.com
http://www.Areca.com.tw
***** RAID is not a substitute for proper and regular backups *****
Eric Hansen
on May 7, 2013 at 6:28:52 pm
Ricardo
i'm surprised to see the writes so much faster than the reads in your tests. is that the case, or are the number flipped?
thanks
e
Eric Hansen
Ricardo Reyes
on May 7, 2013 at 9:31:54 pm
Nope, they are correct. We start seeing faster read performance with more drives.
For example, the same test using 8x Hitachi Ultrastar drives in RAID 5 show the following.
Read - 710MB/s
Write - 855MB/s
Ricardo Reyes
Ricardo@ArecaUS.com
Ricardo Reyes
on May 7, 2013 at 5:31:14 pm
The WD Red drives are 5400RPM drives. Here's some benchmarks comparing both the WD RE and WD Red drives we just conducted last week.
4x Drives RAID 5 - Using Macbook PRO connected to the Areca ARC-8050 Thunderbolt Unit.
WD RE (WD4001FYYG)
Read - 375MB/s
Write - 530MB/s
WD Red (WD30EFRX)
Read - 211MB/s
Write - 489MB/s
No surprise, the 7200RPM WD RE drives are much faster.
And, if your wondering how the WD RE compares with the Hitachi Ultrastar, here's the benchmark numbers we got.
Hitachi Ultrastar
Read - 342MB/s
Write - 525MB/s
The performance of the WD RE and Hitachi Ultrastar are very similar, Again no surprise since they do share the same overall design and both use the 5x 800GB platters. It comes down to user preference, mine is the WD RE.
Ricardo Reyes
Ricardo@ArecaUS.com
Jon Schilling
on May 7, 2013 at 5:18:20 pm
Eric,
You are correct.
HGST (formerly Hitachi Global Storage Technologies) is a wholly owned subsidiary of Western Digital that sells hard disk drives, solid-state drives, and external ...
http://www.hgst.com To me it kind of looks like it's HGST by WD, which IS confusing.
Thanks for correcting me, you'll see Ultrastar drives there.
Jonathan Schilling
12221 Florence Ave.
Dir: 562-777-3498
Fax: 562-777-3499
Alex Gerulaitis
on May 7, 2013 at 10:58:15 pm
[peter tours] " I was concerned over whether the jump from 3 to 6gb/s and 32 to 64mb cache would be tolerated."
Far as I know, 3G vs. 6G is a non-issue as either bus is much faster than the drive's media transfer rate. Fast spinning drives like WD RE and Ultrastars transfer at about 160MB/s while SATA 3G tops out at about 300MB/s. Upping the bus speed to 6G does very little to improve performance - unless you're dealing with external drives (port multiplier eSATA) or SSDs.
Just my two cents.
Alex Gerulaitis
Systems Engineer
DV411 - Los Angeles, CA
Rainer Wirth
on May 9, 2013 at 6:01:26 pm
I would keep the system drive and replace the three others with 3x4TB Hitachi Ultrastars (now WD). You system will provide enough power to handle DVCProHd or any other HD material except 4K.
Cheers
Rainer
factstory
Rainer Wirth
Mac pro 8core
Adobe,FCP,Avid
shawn koppenhoefer
on Aug 5, 2013 at 6:07:02 pm
??And this suggestion would then use SoftRaid or Apples Software Raid,.. since the Apple Raid Controller can NOT handle >2.2TB. Best is 4x2TB
peter tours
on Aug 5, 2013 at 6:52:11 pm
Not software RAID, you were right that it's the Apple Raid card. 2tb limit is what I suspected. What about 3mbs vs 6 mbs.
According to Blackmagic drive speed app, my write speed is around 240mbs and my read speed is slightly higher - would this improve with a software raid? Otherwise I still see no benefit from removing it.
Peter Tours
Fort Lauderdale, FL
TRI EA5 1974-1977
