mounting western digital drive outside housing
COW Forums : RAID Set-Up
Stephen Franciosa
on Apr 2, 2013 at 7:08:15 pm
sorry if this is the wrong forum but I figured you guys understand drives. I was trying to mount my western digital 2tb mybook outside of its housing so i could take advantage of the sata speeds. (the housing only has 800 ports).
i am using a voyager dock and a lacie sata to thunderbolt connection. the drive pops up but cannot be read. i put it back into the housing and it works fine.
how come it wont read outside of the housing?
Rainer Wirth
Re: mounting western digital drive outside housing
on Apr 2, 2013 at 10:11:11 pm
Hi Stephen,
if you want a professional advice: Don't fiddle around with drives in a fixed housing - it does no good. You are lucky you didn't loose your drive.
Anyway - there are a lot of housings on the market, where you can swop harddrives with different connections (faster than USB).
Cheers
Rainer
factstory
Rainer Wirth
phone_0049-177-2156086
Mac pro 8core
Adobe,FCP,Avid
several raid systems
Stephen Franciosa
on Apr 2, 2013 at 10:49:02 pm
i hear ya. any you recommend?
Rainer Wirth
on Apr 5, 2013 at 5:39:34 pm
We work with a USB 3.0 Icybox and Hitachi Deskstars. If you want eSata connectivity look for Raidsonic housings.
Cheers,
Rainer
factstory
Rainer Wirth
Mac pro 8core
Adobe,FCP,Avid
Brett Sherman
on Jun 22, 2013 at 2:48:58 pm
I've had nothing but trouble with the "toaster" style enclosures. I'd suggest getting one with a trayless slot.
http://www.datoptic.com/esata-usb3-usb2-fw400-fw800-sata-enclosure.html
or think about getting one with 4 trays.
http://www.datoptic.com/usb3-esata-four-tray-less-jbod-raid-enclosure.html
I also have some Icybox style enclosures and they work great as long as you're not swapping drives a lot. THey are by far the most affordable option. There are many companies using the same hardware. THis is identical:
http://www.newegg.com/Product/Product.aspx?Item=N82E16816111203
Stephen Franciosa
on Jun 24, 2013 at 12:29:13 pm
thanks for the reply. i've been using these. so far so good.
http://www.newertech.com/products/voyagerq.php
