Areca ARC-1882X with two RAID 6 enclosures?
COW Forums : RAID Set-Up
Ken Brinkley
on Apr 1, 2013 at 5:35:26 pm
Hello! My first post here.
I have an Areca ARC-1882X SAS controller (latest firmware installed) feeding a SansDigital SANS DIGITAL EliteSTOR ES316X6+BS 16 bay RAID 6 array. I recently purchased a Sans Digital EliteSTOR ES208X6+B 8 bay RAID 6 enclosure to use for backing up projects.
When I connect the new enclosure to the Areca (both boxes directly connected to the Areca), it only detects the 16 bay enclosure on startup, but when launching ARCHTTP manager, it sees both enclosures. The problem in that Windows 7 only sees the first drive connected.
I then connected the new box to the SAS expander out port on the first box, but get the same results.
Can I get this set-up to work, or will I need a second controller card to use both boxes at the same time?
Windows 7
ASUS P9X79
Thank you for any ideas or info.
Ken
Alex Gerulaitis
Re: Areca ARC-1882X with two RAID 6 enclosures?
on Apr 1, 2013 at 6:46:29 pm
It should see both boxes. Are the drives initialized in the 2nd box (added to the first RAID set or set up as a 2nd one)? Windows won't see the new drives unless you do that and if you set up a 2nd RAID set, you will also need to create a volume for it in disk management in Windows. If you add them to the existing set, you will need to "expand a volume" in Windows.
Alex Gerulaitis
Systems Engineer
DV411 - Los Angeles, CA
Ken Brinkley
on Apr 1, 2013 at 8:37:48 pm
Hi Alex
The second box is set up as a separate RAID array, and the volume was set up in Windows. If I turn off the original box, Windows sees the new box just fine. It just won't see both boxes at once.
thanks
ken
Alex Gerulaitis
on Apr 1, 2013 at 9:38:42 pm
[Ken Brinkley] "It just won't see both boxes at once."
This is weird, and isn't normal behavior. I'd call Areca support on this, and start drilling down on troubleshooting checklist, i.e. put just one drive in each enclosure, in various bays, see if they can be seen by the system at the same time, try a different HBA or RAID controller.
Alex Gerulaitis
Systems Engineer
Bob Zelin
on Apr 2, 2013 at 12:16:39 am
you see, Ken, next time you will hire Alex directly (or someone like him - these are called VALUE ADDED RESELLERS) instead of buying from a mail order discount house, and realize that nothing is working. It's not fun when nothing works, is it ?
Go into your MRAID Utility (you did load this in from the Areca website, didn't you ?) and select Volume Function, and change the SCSI ID to a different # - you will see that it shows:
0, 0, 0
make the second chassis 0, 0, 1
and you will be able to mount both drives (I never use Windows, but this is in the MRAID utility, not in Win7).
Bob Zelin
Ken Brinkley
on Apr 2, 2013 at 12:57:02 am
[Bob Zelin] "you see, Ken, next time you will hire Alex directly (or someone like him - these are called VALUE ADDED RESELLERS) instead of buying from a mail order discount house, and realize that nothing is working. It's not fun when nothing works, is it ? "
Those are indeed wise words.
You Sir, are a lifesaver. I modified the IDs and it works. All of you are very kind to help out a newbie.
Thank you Alex and Bob!
Ken
Alex Gerulaitis
on Apr 2, 2013 at 5:20:12 pm
[Bob Zelin] "select Volume Function, and change the SCSI ID to a different #"
Perfect - I didn't know that - thanks Bob!
(Ken, could you please mark Bob's post "as a solution"?)
Jon Schilling
on Apr 2, 2013 at 9:49:49 pm
Alex,
Oddly it doesn't look like the "Solution" light bulb is an option anymore.....
Jonathan Schilling
Vertical Sales Manager
Proavio Storage by Enhance Technology Inc.
12221 Florence Ave.
Santa Fe Springs, CA 90670
Dir: 562-777-3498
Main: 562-777-3488 X106
Fax: 562-777-3499
Email: jon@proavio.com
Alex Gerulaitis
on Apr 2, 2013 at 10:02:20 pm
I believe only the OP (and maybe a moderator) has the option of "kudos" and "solution".
Jon Schilling
on Apr 2, 2013 at 10:16:36 pm
I used to see that option all the time, regardless of whether it was a thread I posted on our not. As a "Cow Leader" I would think I'd still have that option, apparently not.
Jonathan Schilling
12221 Florence Ave.
Dir: 562-777-3498
Fax: 562-777-3499
2013 NAB Booth SL7408
Ken Brinkley
on Apr 2, 2013 at 11:27:17 pm
I hit the check mark. I think that it is now marked.
Thanks again
Ken
