Simple PC Backup solution?
COW Forums : RAID Set-Up
Joel Dalls
on Jan 12, 2013 at 7:28:24 pm
Hi I have a Dell Precision T3500 64 bit WIN7 12 gb system with a striped 2 TB HD config. I typically have less than a TB of storage used.
I am in need of a very simple single external HD / USB connected / And Software solution ... a once nightly backup which would allow me to retrive individual files if necessary.
I have loked at the Seagate 2tb drive with "easy-to-use Seagate Dashboard":
http://www.amazon.com/gp/product/B00834SJS0/ref=ox_sc_act_title_1?ie=UTF8&p...
Can anyone recommend this or another strategy. Just need the simplest backup possible that is proven to play well with WIN7.
Many Thanks!!!!
Alex Gerulaitis
Re: Simple PC Backup solution?
on Jan 13, 2013 at 4:04:11 am
Have you tried Windows 7 Backup?
(I try to avoid proprietary and uncommon backup software in case the vendor drops into obscurity and stops supporting it.)
Alex Gerulaitis
Systems Engineer
DV411 - Los Angeles, CA
Joel Dalls
on Jan 13, 2013 at 5:02:35 pm
Thats the direction I am headed for the reasons you mention.
Would this Seagate be a wise choice? Currently I only have USB 2.0 but could get a 3.0 PCI card...
I also use an Aluratek external dock for offline storage transfers and was thinking about just getting a bare seagate 1tb drive.
Many thanks!
Todd Perchert
on Jan 14, 2013 at 3:05:01 pm
For simple file backup on Windows, I also like SyncToy from Microsoft. Makes retrieving single files even easier.
http://www.microsoft.com/en-us/download/details.aspx?id=15155
Brian Cooney
on Jan 14, 2013 at 3:34:14 pm
Alex, I purchased a Pegasus R4 and am very unhappy with it. Locks up my system, hangs.. Sent a report to Promise via the Promise Utility and they said there is a bad sector in bay 1. They offered to replace it. I've only had the array for one week. I asked them if they were coming out with a fix.. but there was no response there as it obviously is a connectivity issue. I'm thinking of sendign this back to B & H today and was looking at the Lacie or OWC arrays that have USB3.0 connectivity. What do you suggest? USB3.0 should be fast enough for animation and video editing in a RAID 5 configuration? thanks.
MotionFoundry, Inc. Video Post
Clients: GM, AOL, Kohl's, 3 Doors Down, IKEA, Kelloggs, Toyota, Thomas Nelson, NASCAR Affiliates
