Is an this G-RAID External Hard Drive Array overkill?
COW Forums : RAID Set-Up
Kristyn Davis
on Sep 25, 2012 at 5:57:23 pm
Hi everyone,
I'm doing a docu-series with some buddies of mine. Each episode will be 30-min long and shot in HD. I'm going to get a new hard drive for the series, so I'm looking at the G-Technology 4 TB G-Drive Professional External Hard Drive and the G-Technology 4TB G-RAID External Hard Drive Array.
I'm going to be using someone else's computer for this project so I can't change any of their configuration, or buy anything that I can't take with me when I leave. Would the second drive be overkill or even work properly on a computer with no RAID config whatsoever?
Thanks for your help!
Rainer Wirth
Re: Is an this G-RAID External Hard Drive Array overkill?
on Nov 13, 2012 at 3:45:24 pm
First of all:
G-Raid raid level5
get the best hd's available (Hitachi Ultrastars to me)
test it on your working environment.
Take one spare disc with you! (for the G-Raid)
The second back up you can do on a normal USB Harddisc. If you have huge data go with your normal Harddisc over FW (need a FW Port)
Good luck
Rainer
