5 X 146GB raid 5 extend
COW Forums : RAID Set-Up
Ajay Kamble
on Aug 4, 2012 at 9:30:48 am
HI!,
I am new to raid array & want to extend existing raid 5.
I need help to extend array.the current setup is as follows,
Array A
unused space : 349956 MB
logical drive :1
total size 273GB
raid5
disk : /dev/cciss/c0d0
physical
1I:1:5 - 146gb
2I:1:1 - 146gb
2I:1:2 - 146gb
2I:1:3 - 146gb
2I:1:4 - 146gb
now I want to use unused space. How can I extend the array using unused space?
another thing I have 2 more unassigned disk.
1I:1:6
1I:1:7
if I want to use that too, how I can extend the existing array?
I dont want to loose any data. server is in production.
so I want to use "hpacucli" command.
all help appreciate.
Ajay
Alex Gerulaitis
Re: 5 X 146GB raid 5 extend
on Aug 7, 2012 at 6:58:37 am
Sounds like an HP RAID controller? HP server as well? Which ones? The OS - Linux?
Did you see this tutorial?
Have you tried running an HP ACU GUI version? (That would make array expansion a no-brainer.)
Alex Gerulaitis
Systems Integrator
DV411 - Los Angeles, CA
