ProAvio 800MS Problem
COW Forums : RAID Set-Up
Felix Knöchel
on Jul 4, 2012 at 5:45:51 pm
I might have a problem with my proavio 800MS. I run it with a Highpoint 2322 RAIDROCKET card on a Win7 Pro 64bit system.
This morning, the LED on the second harddrive wasn't on so I checked the RAID manager. It said everything is fine on Channel two, but still no LED. Then I started "verifying"the array. Now the LED on the 2nd drive is green. All the others are still blue. What does that mean?
Anybody an idea?
Luis Rodriguez
Re: ProAvio 800MS Problem
on Jul 5, 2012 at 5:04:15 pm
Hi Felix,
The Green LED indicates a problem with the drive. Go into the SMART (SHI) section of the Highpoint UI and let's take a look at the health status of drive 2. If the drive does not show any errors, we can take a look at the EVENT LOG to get some if there is any recent information on disk 2.
Please forward a copy of the log to when you have a moment.
Luis Rodriguez
12221 Florence Ave.
Santa Fe Springs, CA 90670
Dir: 562-777-3498
Main: 562-777-3488 X109
Fax: 562-777-3499
© 2018 All Rights Reserved
