Good RAID Englosure for 'green' drives.
COW Forums : RAID Set-Up
Ben Edwards
on May 21, 2012 at 9:33:51 pm
I have a 4 bay StarTech RAID enclosure (S354UFER) with 4x2GB Samsung (ECO Green) Spinpoint HD204UI Drives. I was having a problem with video not playing smoothly and StarTech said they did not recomend 'green' drives as the power saving in the enclose can conflict with power saving in drive. This may be why I am only getting 60MB/s with RAID 10.
So my question is what 4 bay RAID enclosure do people recommend. I have a MacPro Desktop so FW800 seems my best option?
Regards,
Ben
Ben Edwards - Freelance Picture Editor
http://www.funkytwig.com
Macpro1,1 2007 6GB RAM 2*2 3Ghz Xeon
Jon Schilling
Re: Good RAID Englosure for 'green' drives.
on May 21, 2012 at 10:27:24 pm
Hey Ben.
I've never recommended "Green" drives in a RAID for the reason that was pointed out to you among others (namely reliability). I can't say I've ever heard of Green drives being used in anything but the lowest end single drive enclosures.
Is FW800 the "BEST" choice in the machine you have? No.
You could go with mini-SAS, but you'd need to invest in a RAID controller to get speed and data redundancy, something like what we sell, EB400MS: http://www.proavio.com/eb400ms-mini-sas-desktop-raid-ready-storage.html, along with a Areca 1223X card which would afford you 450MB/s in RAID 5, if you had the budget & the expansion of an 8 lane or better slot available to you. Or you could also go with a EB800MS http://www.proavio.com/eb800ms-mini-sas-desktop-raid-ready-storage.html with that same Areca card & get 900MB/s read write in RAID 5, 800MB/s + read/write in RAID 6, but it all comes down to your budget, need for speed & available PCIe slots in your machine.
People that use our products are very satisfied with the performance, protection & service that we provide.
Jonathan Schilling
Vertical Sales Manager
Proavio
12221 Florence Ave.
Santa Fe Springs, CA 90670
Dir: 562-777-3498
Main: 562-777-3488 X106
Fax: 562-777-3499
Email: jon@proavio.com
See our forum: http://forums.creativecow.net/proavio
Ben Edwards
on May 22, 2012 at 10:25:21 am
Yes, I think the issue is green drives are not good for streaming hidef video. Depends how you define best;). I am using the drives for video editing, not high speed backups. I am a student so affordability is a issue. What I am thinking of doing is replacing the drives wit Hitachi DeskStar 72000 as I do not think they are green. 60MB/s is over twice what I need.
Ben
Jon Schilling
on May 22, 2012 at 4:43:43 pm
Ben,
You should be MUCH happier with those drives. Let us know how that pans out for you.
Jonathan Schilling
Proavio
12221 Florence Ave.
Dir: 562-777-3498
Fax: 562-777-3499
Ben Edwards
on May 22, 2012 at 5:15:20 pm
Thanks, are the Seagare Barracudas any good?
Ben
Luis Rodriguez
on May 22, 2012 at 5:42:41 pm
Seagate Barracudas are great if you are running compatible firmware. I would save myself the headache and go with Hitachi.
Luis Rodriguez
Proavio
12221 Florence Ave.
Dir: 562-777-3498
Main: 562-777-3488 X109
Fax: 562-777-3499
Email: luis@proavio.com
Ben Edwards
Seagate Barracuda for Budget RAID
on May 25, 2012 at 6:06:39 pm
Can you please expand on this, they are around 40% cheaper than the Hitachi. I notice a year or so ago there were problems with the drives but surly that has sorted itself out?
Ben
Jon Schilling
Re: Seagate Barracuda for Budget RAID
on May 25, 2012 at 6:26:29 pm
Ben,
The potential problem with Seagate drives is not with the drives, but the firmware. Some Seagate drives may not have the same firmware, drive to drive. You could potentially update the firmware for use with the system you're using, controller card, etc, but that would require getting the firmware from Seagate & installing it, which requires a PC running in DOS.
In the end, you're better off going the hassle-free route of using Hitachi drives.
Jonathan Schilling
Proavio
12221 Florence Ave.
Dir: 562-777-3498
Fax: 562-777-3499
Luis Rodriguez
on May 22, 2012 at 1:11:36 am
Although "green" drives are not recommended for RAID use, it sounds like you may be reaching the FW800 chipset limitation on your Startech enclosure at 60MB/s in RAID-10.
Luis Rodriguez
Proavio
12221 Florence Ave.
Dir: 562-777-3498
Fax: 562-777-3499
