RAID Drive Continuously Develops Bad Blocks
COW Forums : RAID Set-Up
Wes Browning
on May 2, 2012 at 2:50:42 pm
I have a RAID drive that keeps developing bad blocks, and even after switching out drives, I continue to get errors. The message I receive from Drive Genius is: "OWC Mercury Pro RAID Media ("media" is the volume's name) contains to bad blocks. The drive should be backed up and erased as soon as possible."
Here's my current configuration:
OWC Mercury Pro RAID drive (eSata/FW800/USB connections) - Configured as RAID 0
Two Hitachi DeskStar 7K3000 2TB drives.
Sonnet Echo ExpressCard/34 Thunderbolt adapter with Sonnet Tempo SATA ExpressCard/34 Controller Card (using eSata from drive to convert to Thunderbolt connection)
iMac mid-2011 machine with Thunderbolt ports, running most Adobe Premiere and After Effects
I originally had Seagate drives in it back in January, but then put new Hitachi drives in it last month. Its still developing bad blocks though.
Jon Schilling
Re: RAID Drive Continuously Develops Bad Blocks
on May 2, 2012 at 4:19:11 pm
Have you tried contacting OWC directly on your issue? I'd do that as a 1st step. Make sure the drives you're using are compatible with their enclosure.
Jonathan Schilling
Vertical Sales Manager
12221 Florence Ave.
Santa Fe Springs, CA 90670
Dir: 562-777-3498
Main: 562-777-3488 X106
Fax: 562-777-3499
See our forum:
© 2018 All Rights Reserved
