LaCie 12TB 4Big Quadra External Hard Drive RAID Array
COW Forums : RAID Set-Up
Mark Laslo
on Dec 13, 2011 at 3:55:25 pm
Hi All,
Sorry if this is a redundant post, I tried to search out similar threads but didn't have much success.
I am looking into purchasing the LaCie 12TB 4Big - as well as their controller card -
The function of this drive will be to edit using FCP with as well as final storage for finished products. I will also be backing up completed projects to a separate 2 TB time capsule so that if the whole unit fails everything isn't lost.
My questions are
1. I'm working with Final Cut Pro using 1 - 3 streams of Pro Res 422, will this be fast enough to handle that in a RAID 5 configuration
2. Is there a way to control the drive using the card I linked to or do I have to use the onboard controller and just get a regular eSATA card.
3. Any other suggested products for under $1700. DIY can be an option.
Thank you for all of your help,
© 2018 All Rights Reserved
