New versions of FFMPEG and command line syntax
COW Forums : FFmpeg
Stan Juznitok
on Aug 30, 2012 at 6:44:20 pm
Hello,
Can somebody please help me with the newer versions of FFMPEG -- recently I downloaded the Windows version built on 07/16/2012 from zeranoe.org. Using the new syntax form for command line I tried to compress the video with x264:
ffmpeg.exe -i akiyo_cif.avi -r 10 -vcodec libx264 -profile:v baseline -b 50k akiyo.avi
but I'm getting error that I really dont understand what is going on (see below). I have used before the builds dating from 2010 and I didn't have any problems, but I don't now how to write correct commandle line for new versions (I tried also the versions from 2012/07/08).
Thank you!!!
libpostproc 52. 0.100 / 52. 0.100
[h264 @ 0238e520] brainfart cropping not supported, cropping disabled (right: 1,
bottom: 87)
Last message repeated 3 times
[h264 @ 0238e520] top block unavailable for requested intra4x4 mode -1 at 0 0
[h264 @ 0238e520] error while decoding MB 0 0, bytestream (62803)
[h264 @ 0238e520] concealing 24 DC, 24 AC, 24 MV errors
[h264 @ 0238e520] QP 5738 out of range
[h264 @ 0238e520] decode_slice_header error
[h264 @ 0238e520] QP 9834 out of range
[h264 @ 0238e520] deblocking_filter_idc 32 out of range
[h264 @ 0238e520] illegal memory management control operation 32
[h264 @ 0238e520] illegal short term buffer state detected
[h264 @ 0238e520] mmco: unref short failure
[h264 @ 0238e520] cabac_init_idc overflow
[h264 @ 0238e520] QP 3789 out of range
[h264 @ 0238e520] illegal reordering_of_pic_nums_idc
[h264 @ 0238e520] abs_diff_pic_num overflow
[h264 @ 0238e520] long_term_pic_idx overflow
[h264 @ 0238e520] reference picture missing during reorder
[h264 @ 0238e520] reference count overflow
[h264 @ 0238e520] reference overflow 16793 > 15 or 0 > 31
[h264 @ 0238e520] Missing reference picture
Last message repeated 6 times
Last message repeated 2 times
Last message repeated 4 times
Last message repeated 1 times
[h264 @ 0238e520] QP 4294966484 out of range
Michael Rampe
Re: New versions of FFMPEG and command line syntax
on Sep 1, 2012 at 10:52:04 pm
Can you post the full output?
It looks like most of your overflow errors are probably caused by the ridiculously low bitrate of 50k. Try 500k or 1000k..... Or it could be an issue with the source.
Michael
P.s. I love the wording of this error:
"brainfart cropping not supported"
Hahahaha
