combining two .mov files to play along side of one another
COW Forums : FFmpeg
martin edwards
on Jul 30, 2012 at 12:48:00 pm
I'm trying to get two .mov files to play in unison with each other side by side and also have a caption at the bottom of each file, anyone any ideas.
I have it installed on windows 7 and an going through the command line.
I'm also new at this so any answers will need to be explained in detail
here is what I have already
ffmpeg -i orig.mov -an -vcodec v210 -vf "pad=2*iw+30:ih+20:10:10:blue [orig]; movie=2a.mov [new] ; [orig][new] overlay=740:10 [overlay]; [overlay] drawtext=fontfile=C:/windows/fonts/FreeSerif.ttf:fontsize=32:fontcolor=white@0.3:box=1:boxcolor=black@0.3:text=orig.mov:x=300:y=530 [text1]; [text1] draw text=fontfile=C:/windows/fonts/FreeSerif.ttf:fontsize=32:fontcolor=white@0.3:box=1:boxcolor=black@0.3:text=2a.mov:x=1020:y=530 [text2] ; [text2] yadif=0:-1:0 [out]" -sameq -vcodec v210 2a_sbs.mov
but i'm getting an error:
No such filter: 'drawtext'
Error opening filters!
cheers
Reuben Martin
Re: combining two .mov files to play along side of one another
on Aug 2, 2012 at 1:28:57 am
First check that the build you are using supports that filter.
To get a listing of available filters:
ffmpeg -filters
Michael Rampe
on Aug 2, 2012 at 6:15:37 am
Good advice. It is also important to know that the filter in question (drawtext) has a dependency of libfreetype which you must install first and the enable in FFmpeg by using --enable-libfreetype.
Michael
