Can you read timecode into a log file?
COW Forums : FFmpeg
Angelo Lorenzo
on Jul 19, 2012 at 1:24:47 am
Since FFMPEG and FFMBC can't copy a data stream from a Quicktime file (where timecode is stored), I have to resort to setting the timecode using the -timecode command in some instances.
Is there any way to read the filename and timecode into a log file that I can then use to power a python script or batch file for when I actually convert the MOV file?
Angelo Lorenzo
Fallen Empire - Digital Production Services
RED transcoding, on-set DIT, and RED Epic rental services.
Fallen Empire - The Blog
A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
Angelo Lorenzo
Re: Can you read timecode into a log file?
on Jul 19, 2012 at 2:06:47 am
Nevermind, seems like the 2> command will do just fine.
Angelo Lorenzo
Mark Burton
on Mar 5, 2015 at 9:23:27 pm
Could you elaborate on what you ended up doing? I'm looking for a way to read the input files timecode and make the starting timecode value available to the drawtext filter so I can burn it into the picture. Currently I'm having to set the timecode manually for each input file. Thanks.
