getting video specs using ffmpeg
COW Forums : FFmpeg
Peter Robertson
on Jun 8, 2012 at 5:01:53 pm
Is it possible to use ffmpeg to get the specs of an input file (bitrate, size, pixel format, codec etc.)?
How would I do this?
Pedro
Pedro
stephen dixon
Re: getting video specs using ffmpeg
on Jun 10, 2012 at 12:34:06 pm
ffprobe. It comes with ffmpeg, just like ffplay.
ffprobe /[path/to/your/video.mov
For extra laffs you can redirect the stderr to stdout and pipe it to grep and/or sed if you're using it as part of a larger application, eg:
ffprobe ~/mymovie.mov 2>&1 |grep Duration|sed "s/[A-z :]*\([0-9:.]*\).*/\1/"
00:00:50.66
The sed example above uses OSX's curious sed implementation, you may not need to escape the brackets.
