combining mpeg files
COW Forums : FFmpeg
Peter Robertson
on Jun 6, 2012 at 4:56:27 pm
I'm using this:
ffmpeg cat test_0.mpeg test_12.mpeg > comp.mpeg
to combine to files. The output file (comp.mpeg) is only the second file. Each of the input files is 10 seconds. Am I missing something here? Why is my first file not merged with the second??
Thanks.
Pedro
Pedro
Reuben Martin
Re: combining mpeg files
on Jun 7, 2012 at 3:04:43 am
cat test_0.mpeg test_12.mpeg | ffmpeg -i - -vcodec copy -acodec copy -f mpeg comp.mpeg
Peter Robertson
on Jun 8, 2012 at 4:54:33 pm
That works! Thanks.
Pedro
Pedro
stephen dixon
on Jun 12, 2012 at 12:42:48 pm
You don't need to pipe it through ffmpeg. What you're doing wrong is using > instead of >>
The single angle brace overwrites whatever's already in the file, the double brace appends it to the end. See section 3.6.3 here
