Resolution limit?
COW Forums : FFmpeg
Tim Kinnel
Resolution limit?
on Jun 4, 2012 at 10:10:39 pm
I am using ffmpeg to convert video from mov to mp4 and to reduce the resolution from 640x360 to 320x180. However, the video comes out at 480x270. I am using the following command:
ffmpeg -y -i "source.mov" -vcodec libx264 -s 320x180 -b 1000k -r 15 -vpre slow_firstpass -an "output_320x180.mp4"
Does anyone have any hints about what might be going on? Thanks!
Cheers,
Tim
stephen dixon
Re: Resolution limit?
on Jun 5, 2012 at 2:01:45 am
Weird. You could try using libavfilter to do it: -vf scale="320:180"
Stephen Dixon
Editor, Animator, Motionographer
Museum Victoria
Tim Kinnel
on Jun 5, 2012 at 2:07:59 pm
Thanks for the suggestion, which I tried. Same result.
stephen dixon
on Jun 5, 2012 at 3:23:20 pm
Hmm. Post the results you get on the command line
