Changing containers from mp4 to mkv, with subtitles (created with Handbrake)
COW Forums : FFmpeg
Felipe Garcia
on Mar 20, 2012 at 10:42:32 am
I am trying to move a mp4 file that has subtitles created with Handbrake to a mkv container employing ffmpeg and I get an error. I know it is related to the subtitles and to the fact of changing container, because I had no problems re-encoding the audio in the same container and keeping subtitles and video unchanged and I also had no problems when I excluded the subtitles and changed container from mp4 to mkv.
I tried both to copy the subtitle unchanged and to re-encode it and none work. Here are the commands and the error messages:
ffmpeg -i SpringLecture2011.mp4 -map 0 -c copy SpringLecture2011.mkv
Could not write header for output file #0 (incorrect codec parameters ?)
ffmpeg -i SpringLecture2011.mp4 -map 0 -c:v copy -c:a copy -codec:s srt SpringLecture2011.mkv
Data stream encoding not supported yet (only streamcopy)
Any idea of what could be the cause of this error and the way to solve it?
Thanks in advance!
Here is the whole output of both commands:
$ ffmpeg -i SpringLecture2011.mp4 -map 0 -c copy SpringLecture2011.mkv
ffmpeg version N-38847-g219a6fb Copyright (c) 2000-2012 the FFmpeg developers
built on Mar 17 2012 22:37:47 with gcc 4.6.3
configuration: --prefix=/usr/local --enable-gpl --enable-version3 --enable-nonfree --enable-x11grab --enable-small --enable-libaacplus --enable-libass --enable-libdirac --enable-libfaac --enable-libfreetype --enable-libmp3lame --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-libvpx --enable-libx264 --enable-postproc --enable-pthreads --enable-libopencore-amrnb --enable-libvo-amrwbenc
libavutil 51. 42.100 / 51. 42.100
libavcodec 54. 10.100 / 54. 10.100
libavformat 54. 2.100 / 54. 2.100
libavdevice 53. 4.100 / 53. 4.100
libavfilter 2. 65.100 / 2. 65.100
libswscale 2. 1.100 / 2. 1.100
libswresample 0. 7.100 / 0. 7.100
libpostproc 52. 0.100 / 52. 0.100
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'SpringLecture2011.mp4':
Metadata:
major_brand : isom
minor_version : 512
compatible_brands: isomiso2avc1mp41
creation_time : 2012-03-12 21:46:15
encoder : Lavf54.2.100
Duration: 01:22:24.54, start: 0.000000, bitrate: 235 kb/s
Chapter #0.0: start 0.000000, end 344.844500
Metadata:
title : Chapter 1
Chapter #0.1: start 344.844500, end 1058.657600
Metadata:
title : Chapter 2
Chapter #0.2: start 1058.657600, end 1501.099600
Metadata:
title : Chapter 3
Chapter #0.3: start 1501.099600, end 1861.459600
Metadata:
title : Chapter 4
Chapter #0.4: start 1861.459600, end 2375.973600
Metadata:
title : Chapter 5
Chapter #0.5: start 2375.973600, end 2726.323600
Metadata:
title : Chapter 6
Chapter #0.6: start 2726.323600, end 3261.057800
Metadata:
title : Chapter 7
Chapter #0.7: start 3261.057800, end 3704.300600
Metadata:
title : Chapter 8
Chapter #0.8: start 3704.300600, end 3827.924100
Metadata:
title : Chapter 9
Chapter #0.9: start 3827.924100, end 4148.744600
Metadata:
title : Chapter 10
Chapter #0.10: start 4148.744600, end 4340.936600
Metadata:
title : Chapter 11
Chapter #0.11: start 4340.936600, end 4944.540000
Metadata:
title : Chapter 12
Stream #0:0(und): Video: h264 (avc1 / 0x31637661), yuv420p, 712x480 [SAR 8:9 DAR 178:135], 124 kb/s, 29.97 fps, 29.97 tbr, 90k tbn, 180k tbc
Metadata:
handler_name : VideoHandler
Stream #0:1(eng): Audio: aac (mp4a / 0x6134706D), 48000 Hz, 2 channels (FC), s16, 32 kb/s
Metadata:
handler_name : SoundHandler
Stream #0:2(fra): Audio: aac (mp4a / 0x6134706D), 48000 Hz, 2 channels (FC), s16, 31 kb/s
Metadata:
Stream #0:3(spa): Audio: aac (mp4a / 0x6134706D), 48000 Hz, 2 channels (FC), s16, 31 kb/s
Metadata:
Stream #0:4(eng): Data: unknown_codec ([224][0][0][0] / 0x00E0)
Metadata:
handler_name : SubtitleHandler
Stream #0:5(und): Subtitle: unknown_codec (tx3g / 0x67337874)
Metadata:
handler_name :
[matroska @ 0xadfadc0] Only audio, video, and subtitles are supported for Matroska.
[matroska @ 0xadfadc0] Subtitle codec 94213 is not supported.
Output #0, matroska, to 'SpringLecture2011.mkv':
Metadata:
major_brand : isom
minor_version : 512
Metadata:
title : Chapter 1
Metadata:
title : Chapter 2
Metadata:
title : Chapter 3
Metadata:
title : Chapter 4
Metadata:
title : Chapter 5
Metadata:
title : Chapter 6
Metadata:
title : Chapter 7
Metadata:
title : Chapter 8
Metadata:
title : Chapter 9
Metadata:
title : Chapter 10
Metadata:
title : Chapter 11
Metadata:
title : Chapter 12
Stream #0:0(und): Video: h264 (avc1 / 0x31637661), yuv420p, 712x480 [SAR 8:9 DAR 178:135], q=2-31, 124 kb/s, 29.97 fps, 1k tbn, 90k tbc
Metadata:
Stream #0:1(eng): Audio: aac (mp4a / 0x6134706D), 48000 Hz, 2 channels (FC), 32 kb/s
Metadata:
Stream #0:2(fra): Audio: aac (mp4a / 0x6134706D), 48000 Hz, 2 channels (FC), 31 kb/s
Metadata:
Stream #0:3(spa): Audio: aac (mp4a / 0x6134706D), 48000 Hz, 2 channels (FC), 31 kb/s
Metadata:
Metadata:
Metadata:
handler_name :
Stream mapping:
Stream #0:0 -> #0:0 (copy)
Stream #0:1 -> #0:1 (copy)
Stream #0:2 -> #0:2 (copy)
Stream #0:3 -> #0:3 (copy)
Stream #0:4 -> #0:4 (copy)
Stream #0:5 -> #0:5 (copy)
Metadata:
major_brand : isom
minor_version : 512
Metadata:
title : Chapter 1
Metadata:
title : Chapter 2
Metadata:
title : Chapter 3
Metadata:
title : Chapter 4
Metadata:
title : Chapter 5
Metadata:
title : Chapter 6
Metadata:
title : Chapter 7
Metadata:
title : Chapter 8
Metadata:
title : Chapter 9
Metadata:
title : Chapter 10
Metadata:
title : Chapter 11
Metadata:
title : Chapter 12
Metadata:
Metadata:
Metadata:
Metadata:
Metadata:
Metadata:
handler_name :
