COW Forums : FFmpeg
Martyn Morris
on Mar 7, 2012 at 9:32:30 am
Hi there,
I have a Quicktime file that is 1920*1080 wit a Animation codec and I would like to convert it to a .ts or .mpg file MPEG-2 video and MPEG Layer , 48000Hz Stereo(LR) wit a Data rate of 15 mbits/s.
Im not sure how to input the mbit/s as the client has asked for these exact requirements and keeps sending back every render as wrong.
Any help would be grate.
stephen dixon
Re: ffmpegX
on Mar 21, 2012 at 12:00:18 pm
the option is -b 15M. You might consider setting maxrate and minrate and bufsize as well.
Michael Rampe
Re: ffmpegX
on Mar 21, 2012 at 12:29:28 pm
Just noticed the title of this post.....
Are you referring to the very outdated OSX GUI called ffmpegX or the ffmpeg command line program?
FfmpegX was built on a very old ffmpeg version.... not sure if they changed that recently (doubt it).
If you need a GUI, have a look at iFFmpeg for OSX which lets you update the core libraries and stay up to date with the syntax changes.....
Otherwise, bite the bullet and go commando line;-)
© 2018 All Rights Reserved
