Encoding a Windows Media Player compatible DV25 .avi file
COW Forums : FFmpeg
Andreas Wideroe
on Mar 1, 2012 at 9:04:44 pm
The past week I've been playing around with ffmpeg 0.10 installed from source on my FreeBSD 8.2 server.
I'm trying to create a few ffmpeg presets that I can use for various standard encodings.
Ie. one client always wants a DV25 .avi and .mov file of the films we make, an mpeg-2 DVD file and a h264 file for the iPad.
The mpeg-2 and h264 is OK and so is the Quicktime DV25 file (as far as I can tell), but I cannot get the DV25 file to be accepted by Windows Media Player - and an earlier version of Adobe Premiere Pro (version 2). WMP gives the message no codec and Adobe Premiere says unsupported format.
I try with the -target pal-dv, but with no luck.
I want my parameters to work no matter if I encode a 10 bit uncompressed 4x3 file or a HD720P Prores file. As I said, it works for mpeg-2 and h264.
My current sourcefile is a Prores 422HQ 1280x720 50P.
Any suggestions of what I can try to get the DV25 .avi file to work and also for it to be either 16x9 or 4x3 depending on the source file?
I have tried this aswell: -vcodec dvvideo -s 720x576 -pix_fmt yuv420p -r 25 -acodec pcm_s16le -ac 2 -ar 48000
Thanks for your help!!
Best,
Andreas
Filmtek AS
http://www.filmtek.no
Filmshooting | Com
http://www.filmshooting.com
Andreas Wideroe
Re: Encoding a Windows Media Player compatible DV25 .avi file
on Mar 1, 2012 at 10:32:02 pm
I seem to be making some progress with these parameters:
-vcodec dvvideo -s 720x576 -vtag dvsd -pix_fmt yuv420p -r 25 -f avi -acodec pcm_s16le -ac 2 -ar 4
8000
However, when playing back in WMP (which finally works) the 16x9 image is squeezed into a 4x3 frame.
I need to make my parameters flexible so they can take either 4x3 or 16x9 and keep the aspect ratio on the output files, even if it's 16x9 HD downscaled to PAL DV.
Any ideas?
Filmtek AS
Filmshooting | Com
stephen dixon
on Mar 2, 2012 at 12:14:47 pm
Have you used the -aspect option? I believe the parameters are just the ratio as x:y, e.g. 16:9 or 4:3.
You could find the aspect of the original source with ffprobe, a bit of regex hacking would return it as a variable:
AR=$(ffprobe source.mov 2>&1|sed "s/.*PAR[[:space:]]*([0-9]*):([0-9]*).*/1:2/")
then you can use the variable as a parameter in the -aspect option:
ffmpeg -i source.mov [whatever] -aspect $AR [whatever] output.avi
This is assuming you're in a POSIX environment of course.
Stephen Dixon
Editor, Animator, Motionographer
Museum Victoria
Andreas Wideroe
on Mar 6, 2012 at 8:33:11 am
I can't use the aspect tag because the parameters must work with any aspect regardless of what I feed it and it's all done automatically, like a watchfolder.
Anyways, I have concluded that this works in everything but WMP (which I seem to remember have some problems with DV files and 16x9).
-vcodec dvvideo -s 720x576 -vtag dvsd -pix_fmt yuv420p -r 25 -f avi -acodec pcm_s16le -ac 2 -ar 48000
Cheers,
Andreas
Filmtek AS
Filmshooting | Com
stephen dixon
on Mar 21, 2012 at 11:47:31 am
The script I provided would read the aspect of the original and supply it as the variable to be used in the aspect tag, so the output would always match. You will need to change the syntax to suit cmd.exe rather than Bash, as it sounds like you're in a windows environment.
