Streaming with ffserver & ffmpeg. Possible audio encoding issue
COW Forums : FFmpeg
Harold Hunt
on Feb 5, 2012 at 2:15:18 am
Hello,
I'm attempting to stream my desktop and audio with ffmpeg and ffserver. My ffserver config is posted below:
Port 8090
RTSPPort 1234
BindAddress 0.0.0.0
RTSPBindAddress 0.0.0.0
MaxHTTPConnections 2000
MaxClients 1000
MaxBandwidth 1000
CustomLog -
NoDaemon
File /tmp/stream.ffm
FileMaxSize 32M
Feed stream.ffm
Format rtp
File /tmp/stream.sdp
AudioBitRate 64
AudioChannels 1
AudioSampleRate 22050
VideoBitRate 128
VideoBufferSize 400
VideoFrameRate 15
VideoSize 384x240
VideoGopSize 12
VideoHighQuality
Video4MotionVector
AudioCodec libmp3lame
VideoCodec libx264
Also my ffmpeg command that I am using to stream is below.
ffmpeg -f x11grab -r 25 -s 384x240 -i :0.0 -f alsa -ac 2 -ar 44100 -i hw:0,0 -f rtp rtp://192.168.1.102:8090/stream.ffm
It has no problems running, however when I try to use either VLC or mplayer to play the stream, it will crash, both complain about audio not being encoded properly.
Harold
Reuben Martin
Re: Streaming with ffserver & ffmpeg. Possible audio encoding issue
on Feb 5, 2012 at 8:02:41 pm
ffserver is a crusty old relic of the past that is not well maintained. You probably need to encode the video/audio before sending it to ffserver rather than depending on ffserver to transcode it. Not really sure though, I never use it. There are much better alternatives available. http://www.rtmpd.com/
