audio level check with ffmpeg
COW Forums : FFmpeg
Jay Gustafson
on Jan 27, 2012 at 5:23:21 pm
I'm looking to write a script that will check the audio mic level of my mpeg recordings. If there a way to have ffmpeg report the audio level (in dB for example)on a frame-by-frame basis so my script can verify the audio level?
Michael Rampe
Re: audio level check with ffmpeg
on Jan 30, 2012 at 10:19:49 pm
I use SoX for this operation.
http://sox.sourceforge.net/
A command like:
$ sox $INPUT -n stats 2> stats.txt
...will give you a lot of useful data. I found that you get quite inaccurate results on some recordings due to subsonic non-vocal frequencies.
You can also use SoX to filter these out such as:
$ sox $INPUT -n -D highpass 100 stats 2> stats.txt
Let me know if this helps.
Michael
