Split DirectShow Capture
COW Forums : FFmpeg
Luana Black
on Jan 4, 2012 at 3:21:35 pm
I am currently using ffmpeg to capture video and audio from direcshow (windows 7):
ffmpeg.exe -f dshow -i video="V string":audio="A string" -r 25 -t 300 -n output.avi
"-t 300" makes it to capture for 300 seconds (5 mins). But i would like to capure more time splitting the output file in chunks.
For example make a 30 minute recording in 6 chunks of 5 minutes. I could do this in a batch file calling 6 times ffmpeg in a loop, but in this way i lose capture time between the loops (1 second more or less). I would like to do it without losing capture time.
Any way i can make this to happen?
Reuben Martin
Re: Split DirectShow Capture
on Jan 5, 2012 at 2:26:22 am
http://ffmpeg.org/ffmpeg.html#segment
Luana Black
on Jan 5, 2012 at 4:39:37 am
Thanks for your reply. I cant get it to work, i am probably doing something wrong.
ffmpeg.exe -f dshow -s 352x288 -i video="Video WebCam":audio="Micr¢fono (Realtek High Definit" -r 10 -f segment out%03d.avi
ffmpeg version N-36088-gdd1fb65, Copyright (c) 2000-2011 the FFmpeg developers
built on Dec 22 2011 12:39:23 with gcc 4.6.2
configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-runtime-cpudetect --enable-avisynth --enable-bzlib --enable-frei0r --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libfreetype --enable-libgsm --enable-libmp3lame --enable-libopenjpeg --enable-librtmp --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libxavs --enable-libxvid --enable-zlib
libavutil 51. 32.100 / 51. 32.100
libavcodec 53. 47.100 / 53. 47.100
libavformat 53. 28.100 / 53. 28.100
libavdevice 53. 4.100 / 53. 4.100
libavfilter 2. 53. 0 / 2. 53. 0
libswscale 2. 1.100 / 2. 1.100
libswresample 0. 5.100 / 0. 0.100
libpostproc 51. 2.100 / 51. 2.100
[dshow @ 003D8920] Estimating duration from bitrate, this may be inaccurate
Seems stream 0 codec frame rate differs from container frame rate: 10000000.00 (10000000/1) -> 15.00 (15/1)
Input #0, dshow, from 'video=Video WebCam:audio=Micrófono (Realtek High Definit':
Duration: N/A, start: 140270.327000, bitrate: N/A
Stream #0:0: Video: rawvideo (YUY2 / 0x32595559), yuyv422, 352x288, 15 tbr, 10000k tbn, 10000k tbc
Stream #0:1: Audio: pcm_s16le, 44100 Hz, 2 channels, s16, 1411 kb/s
Output #0, segment, to 'out%03d.avi':
Output file #0 does not contain any stream
I also tried this:
ffmpeg.exe -f dshow -s 352x288 -i video="Video WebCam":audio="Micr¢fono (Realtek High Definit" -r 10 -f segment -time 10 out%03d.avi
[dshow @ 00268960] Estimating duration from bitrate, this may be inaccurate
Seems stream 0 codec frame rate differs from container frame rate: 10000000.00 (10000000/1) -> 15.08 (181/12)
Duration: N/A, start: 139833.164000, bitrate: N/A
Stream #0:0: Video: rawvideo (YUY2 / 0x32595559), yuyv422, 352x288, 15.08 tbr, 10000k tbn, 10000k tbc
Unrecognized option 'time'
Failed to set value '10' for option 'time'
I put this just to show and compare how it works without segmenting.
ffmpeg.exe" -f dshow -s 352x288 -i video="Video WebCam":audio="Micr¢fono (Realtek High Definit" -r 10 out.avi
[dshow @ 01F28880] Estimating duration from bitrate, this may be inaccurate
Duration: N/A, start: 139364.511000, bitrate: N/A
Incompatible pixel format 'yuyv422' for codec 'mpeg4', auto-selecting format 'yuv420p'
[buffer @ 02F7FD00] w:352 h:288 pixfmt:yuyv422 tb:1/1000000 sar:0/1 sws_param:
[buffersink @ 02FE4560] auto-inserting filter 'auto-inserted scale 0' between the filter 'src' and the filter 'out'
[scale @ 02F083E0] w:352 h:288 fmt:yuyv422 -> w:352 h:288 fmt:yuv420p flags:0x4
Output #0, avi, to 'out.avi':
Metadata:
ISFT : Lavf53.28.100
Stream #0:0: Video: mpeg4 (FMP4 / 0x34504D46), yuv420p, 352x288, q=2-31, 200 kb/s, 10 tbn, 10 tbc
Stream #0:1: Audio: mp3 (U[0][0][0] / 0x0055), 44100 Hz, 2 channels, s16, 128 kb/s
Stream mapping:
Stream #0:0 -> #0:0 (rawvideo -> mpeg4)
Stream #0:1 -> #0:1 (pcm_s16le -> libmp3lame)
Press [q] to stop, [?] for help
frame= 20 fps= 0 q=1.6 size= 90kB time=00:00:02.40 bitrate= 306.0kbits/s dup=0 drop=10
frame= 25 fps= 23 q=1.6 size= 111kB time=00:00:02.89 bitrate= 313.2kbits/s dup=0 drop=13
frame= 31 fps= 19 q=1.6 size= 132kB time=00:00:03.39 bitrate= 319.4kbits/s dup=0 drop=15
frame= 36 fps= 17 q=1.6 size= 154kB time=00:00:03.91 bitrate= 322.5kbits/s dup=0 drop=18
frame= 41 fps= 15 q=1.6 size= 176kB time=00:00:04.41 bitrate= 325.8kbits/s dup=0 drop=21
Reuben Martin
on Jan 5, 2012 at 10:25:36 pm
Looks like their documentation is out of date. Try something more like this:
ffmpeg.exe -f dshow -s 352x288 -i video="Video WebCam":audio="Micr¢fono (Realtek High Definit" -vcodec ffv1 -acodec pcm_s16le -map 0 -r 10 -f segment -segment_time 10 -container_format avi -segment_pattern %03d -segment_basename output dummy_out.avi
change vcodec/acodec to whatever codec types you are aiming for.
**This is for ver. 0.9.x
Luana Black
on Jan 8, 2012 at 6:23:11 am
Thanks. I tried what you said but it still isnt working:
ffmpeg.exe" -f dshow -s 320x240 -i video="Video WebCam":audio="Micr¢fono (Realtek High Definit" -vcodec ffv1 -acodec pcm_s16le -map 0 -r 5 -f segment -segment_time 10 -container_format avi -segment_pattern %03d -segment_basename output dummy_out.avi
ffmpeg version N-36492-g7f83db3, Copyright (c) 2000-2012 the FFmpeg developers
built on Jan 5 2012 01:57:12 with gcc 4.6.2
libavutil 51. 34.100 / 51. 34.100
libavcodec 53. 53.100 / 53. 53.100
libavformat 53. 29.100 / 53. 29.100
libavfilter 2. 57.101 / 2. 57.101
libswresample 0. 5.100 / 0. 5.100
[dshow @ 02A51A60] Estimating duration from bitrate, this may be inaccurate
Duration: N/A, start: 13425.342000, bitrate: N/A
Stream #0:0: Video: rawvideo (YUY2 / 0x32595559), yuyv422, 320x240, 25 tbr, 10000k tbn, 10000k tbc
Unrecognized option 'container_format'
Failed to set value 'avi' for option 'container_format'
Luana Black
on Jan 8, 2012 at 10:07:09 pm
I have been trying with older ffmpeg builds and i found that with this build it works:
ffmpeg version N-35709-g7d531e8, Copyright (c) 2000-2011 the FFmpeg developers
built on Dec 12 2011 13:50:00 with gcc 4.6.2
libavutil 51. 32. 0 / 51. 32. 0
libavcodec 53. 43. 0 / 53. 43. 0
libavformat 53. 24. 0 / 53. 24. 0
libavdevice 53. 4. 0 / 53. 4. 0
libswscale 2. 1. 0 / 2. 1. 0
libpostproc 51. 2. 0 / 51. 2. 0
I would like to use last build of ffmpeg if possible, but it says "Unrecognized option 'container_format'". Did the segmenting option names change? Is there any way to use segmenting with last build?
Thanks for your replies, i can work with it now.
Reuben Martin
on Jan 9, 2012 at 12:47:34 am
The builds you are using are pulled directly from the git repo. Most likely they are coming from the tip of the development branch, which could have any number of undocumented changes. Furthermore, you don't really know if that is pulled from the mainline git repo, or somebody's private clone which could potentually also have changes in it that differ from the main development.
Trying finding builds of release versions. I am using 0.9.1, which is the most recently tagged release. Unless you need some feature that has been added since the 0.9.x branch was created, you will probably have the benefit of better stability as well.
Luana Black
on Jan 10, 2012 at 6:12:47 am
To close the issue, here can be seen the changes made to segment.c
http://git.videolan.org/?p=ffmpeg.git;a=history;f=libavformat/segment.c;hb=...
On 2011-12-19 was when they changed the variable names to "segment_time", "segment_format"...
I am not using this last version because seems to work worse than 2011-10-17 version.
I has a bug (or i am using it wrong) that if i want to encode a video segmented in 10 sec chunks, the first clip is 10 seconds long, the second 20 seconds long (only last 10 sec with video data), the third is 30 secs long (only last 10 sec with video data), and so on.
