Prores on PC
COW Forums : FFmpeg
Craig RussillRoy
Prores on PC
on Nov 18, 2011 at 9:09:00 pm
Howdy Guys,
I have strayed from the grass into the FFmpeg paster - in FCX Detbate forum there is a comment that the new build of FFmpeg can encode Prores on a pc - can someone check please ?
Adstream London, England
4 x Mac Pros, FCP7, 4 x Flip Factories, 35 x Rhozet Carbon Coders, Offices Globally
Reuben Martin
Re: Prores on PC
on Nov 20, 2011 at 4:34:15 am
There was a major code dump in September that added support for ProRes decoding, and another in October that added encoding support. There has been a lot of incremental work to improve them since that time.
However, I don't believe that any of the official release builds have it built in yet since it is still experimental. You would need to build from git sources if you wanted to test it out.
Initial Commit for ProRes support: http://ffmpeg.org/pipermail/ffmpeg-cvslog/2011-September/040453.html
stephen dixon
Re: Prores on PC
on Mar 21, 2012 at 11:56:04 am
It certainly does now - both encodes and decodes, I use it all the time.
eg ffmpeg -i input.mov -vcodec prores -profile hq -acodec pcm_16sle output.mov will turn input.mov into a prores 422 (HQ) file (the -acodec option is given just because that's how fcp likes it).
