Post processing in ffmpeg to move 'moov atom' in MP4 files (qt-faststart)
COW Forums : FFmpeg
Siddhant Bhansali
on Nov 9, 2011 at 8:55:51 am
Is it possible to run ffmpeg from the command line which will either place the 'moov atom' metadata in the beginning of the MP4 file or run the qt-faststart as a post processing operation in ffmpeg so the generated file is stream-able through the internet?
I can of course run it as a separate command, but would prefer it to be something:
(a) as an option within ffmpeg, or
(b) as part of a post conversion, command line option when converting the video files via ffmpeg
(Crossposted at: http://stackoverflow.com/questions/8061798/post-processing-in-ffmpeg-to-mov... )
Reuben Martin
Re: Post processing in ffmpeg to move 'moov atom' in MP4 files (qt-faststart)
on Nov 12, 2011 at 2:43:09 am
For streaming, you're generally better off to stick it in an MPEG-TS rather than MP4. MP4 _can_ be streamed, but it's not really made for that purpose.
Reuben Martin
on Nov 12, 2011 at 2:44:22 am
BTW, I think if you must use MP4, the MP4Box tool is probably better for that.
http://gpac.wp.institut-telecom.fr/mp4box/
