ffmpeg, create MPEG2 from series of GIFs
COW Forums : FFmpeg
Mark Aren
on Oct 23, 2011 at 5:47:43 am
Hi All,
I have a series of 60 individual, static GIF images, each 720x576 pixels (actually moving hands on a small clock). I wish to encode this to MPEG2 video at 2920kb/s with a duration of 60 seconds (1 sec per GIF frame).
Current command line is
ffmpeg -i tc_%02d.gif -r 1 -y -an -vcodec mpeg2video -b 2920kb -r 25 -s 720x576 TC_ZL3JVX.mpg
Error message is unable to find a suitable output format for TC_ZL3JVX.mpg
The resulting MPG will eventually be muxed into a transport stream for transmission using Digital Amateur TV, but that is a few steps away.
Any help or pointers appreciated.
Mark
daniel paluska
Re: ffmpeg, create MPEG2 from series of GIFs
on Nov 23, 2011 at 8:18:48 pm
have you tried stripping away portions of the command?
starting here:
ffmpeg -i tc_%02d.gif test.mpg
and slowly adding terms until you get to here:
maybe it's a 2 step process.
you could use imagemagick to convert the individual frames to jpgs? maybe it would be happier with that?
or first make a movie without specifying the codec and then transcoding that movie to the final desired state?
