Mux 3gp audio file with jpg image to create video clip
COW Forums : FFmpeg
C David Young
on Sep 24, 2011 at 4:53:02 pm
So far I am getting various errors no matter what combination of things I try. Thanks.
C:Androidimages>C:Androidffmpeg-git-a254452-win32-staticbinffmpeg -y -f image2 -r .2 -i IMAG001.jpg -i "fold doblar.3gp" -acodec copy a.mp4
ffmpeg version N-32726-ga254452, Copyright (c) 2000-2011 the FFmpeg developers
built on Sep 19 2011 19:49:13 with gcc 4.6.1
configuration: --enable-gpl --enable-version3 --enable-runtime-cpudetect --enable-avisynth --enable-bzlib --enable-frei0r --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libfreetype --enable-libgsm --enable-libmp3lame --enable-libopenjpeg --enable-librtmp --enable-libschroedinger --
enable-libspeex --enable-libtheora --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libxavs --enable-libxvid --enable-zlib
libavutil 51. 16. 1 / 51. 16. 1
libavcodec 53. 16. 0 / 53. 16. 0
libavformat 53. 12. 0 / 53. 12. 0
libavdevice 53. 4. 0 / 53. 4. 0
libavfilter 2. 43. 2 / 2. 43. 2
libswscale 2. 1. 0 / 2. 1. 0
libpostproc 51. 2. 0 / 51. 2. 0
Input #0, image2, from 'IMAG001.jpg':
Duration: 00:00:05.00, start: 0.000000, bitrate: N/A
Stream #0.0: Video: mjpeg, yuvj420p, 3264x1952, 0.20 tbr, 0.20 tbn, 0.20 tbc
[amr @ 003DF5E0] max_analyze_duration 5000000 reached at 5000000
[amr @ 003DF5E0] Estimating duration from bitrate, this may be inaccurate
Input #1, amr, from 'fold doblar.3gp':
Duration: 00:00:14.82, bitrate: 12 kb/s
Stream #1.0: Audio: amr_nb (samr / 0x726D6173), 8000 Hz, 1 channels, flt, 12 kb/s
[buffer @ 042720C0] w:3264 h:1952 pixfmt:yuvj420p tb:1/1000000 sar:0/1 sws_param:
[libx264 @ 04247C20] using cpu capabilities: MMX2 SSE2Fast SSSE3 FastShuffle SSE4.1 Cache64
[libx264 @ 04247C20] profile High, level 5.1
[libx264 @ 04247C20] 264 - core 116 r2074 2641b9e - H.264/MPEG-4 AVC codec - Copyleft 2003-2011 - http://www.videolan.org/x264.html - options: cabac=1 ref=3 deblock=1:0:0 analyse=0x3:0x113 me=hex subme=7 psy=1 psy_rd=1.00:0.00 mixed_ref=1 me_range=16 chroma_me=1 trellis=1 8x8dct=1 cqm=0 deadzone=21,
11 fast_pskip=1 chroma_qp_offset=-2 threads=3 sliced_threads=0 nr=0 decimate=1 interlaced=0 bluray_compat=0 constrained_intra=0 bframes=3 b_pyramid=2 b_adapt=1 b_bias=0 direct=1 weightb=1 open_gop=0 weightp=2 keyint=250 keyint_min=1 scenecut=40 intra_refresh=0 rc_lookahead=40 rc=crf mbtree=1 crf=23.
0 qcomp=0.60 qpmin=0 qpmax=69 qpstep=4 ip_ratio=1.40 aq=1:1.00
[mp4 @ 04260820] track 1: could not find tag, codec not currently supported in container
Output #0, mp4, to 'a.mp4':
Metadata:
encoder : Lavf53.12.0
Stream #0.0: Video: h264 (![0][0][0] / 0x0021), yuvj420p, 3264x1952, q=-1--1, 1 tbn, 0.20 tbc
Stream #0.1: Audio: amr_nb (samr / 0x726D6173), 8000 Hz, 1 channels, 12 kb/s
Stream mapping:
Stream #0.0 -> #0.0 (mjpeg -> libx264)
Stream #1.0 -> #0.1 (copy)
Could not write header for output file #0 (incorrect codec parameters ?)
Michael Rampe
Re: Mux 3gp audio file with jpg image to create video clip
on Sep 29, 2011 at 2:02:57 am
[C David Young] "Stream #1.0: Audio: amr_nb (samr / 0x726D6173), 8000 Hz, 1 channels, flt, 12 kb/s"
It looks like the -acodec copy that is giving you grief in the .mp4 container. Try aac (libfaac) or mp3 (libmp3lame) instead.
Michael
C David Young
on Sep 29, 2011 at 5:11:08 am
Thanks for your suggestion, Michael. I am tried aac and got the following error. I also tried just converting the .3gp file to .aac and got the same error. Am I doing anything obviously wrong?
C:\Android\images>C:/Android/ffmpeg-git-a254452-win32-static/bin/ffmpeg -y -i IMAG001.3gp -acodec aac IMAG001.aac
[amr @ 01B785E0] max_analyze_duration 5000000 reached at 5000000
[amr @ 01B785E0] Estimating duration from bitrate, this may be inaccurate
Input #0, amr, from 'IMAG001.3gp':
Duration: 00:00:06.74, bitrate: 12 kb/s
Stream #0.0: Audio: amr_nb (samr / 0x726D6173), 8000 Hz, 1 channels, flt, 12 kb/s
Incompatible sample format 'flt' for codec 'aac', auto-selecting format 's16'
[aac @ 01A07BE0] Too many bits per frame requested
Output #0, adts, to 'IMAG001.aac':
Stream #0.0: Audio: aac, 8000 Hz, 1 channels, s16, 128 kb/s
Stream mapping:
Stream #0.0 -> #0.0 (amrnb -> aac)
Error while opening encoder for output stream #0.0 - maybe incorrect parameters such as bit_rate, rate, width or height
Michael Rampe
on Sep 29, 2011 at 5:35:20 am
Haven't dealt with your input codec before but:
[C David Young] "Error while opening encoder for output stream #0.0 - maybe incorrect parameters such as bit_rate, rate, width or height"
you need to set these parameters...
here are some examples:
bitrate: -ab 128k
rate: -ar 48k
channels: -ac 2
Also, by specifying aac as the encoder, you are using the experimental aac encoder. I would recommend installing libfaac and recompiling FFmpeg with --enable-libfaac. The you would specify -acodec libfaac.
Michael
C David Young
on Sep 29, 2011 at 3:54:34 pm
Thanks for the info. I tried
ffmpeg -y -f image2 -r .2 -i IMAG001.jpg -i IMAG001.3gp -ab 128k -ar 48k -ac 2 -strict experimental -acodec aac IMAG001.mp4
and it does not give me an error now but, as you said, the results were not good. The audio sounds ok but the image is missing.
I'll try recompiling with the --enable-libfaac. It is a good thing that I have spent days trying to get the Win32 cross-compile to work and finally succeeded. I'll give this a try later today. Thanks!
C David Young
on Sep 29, 2011 at 4:31:53 pm
Well, another stumbling block.
../ffmpeg/configure --enable-memalign-hack --arch=x86 --target-os=mingw32 --enable-nonfree --enable-libfaac --cross-prefix=i686-w64-mingw32-
ERROR: libfaac not found
I have the latest git from ffmpeg...
Michael Rampe
on Sep 30, 2011 at 2:14:27 am
[C David Young] "ERROR: libfaac not found"
You need to install libfaac first:
http://www.audiocoding.com/faac.html
And while you are at it, you might as well install x264 and mp3lame as well for flexibility.
Michael
C David Young
on Sep 30, 2011 at 5:46:23 pm
Michael,
Thanks for your patience.
I am trying to follow the instructions in the INSTALL file that follow. Is this the correct way to install libfaac? In particular, the part about libmp4v2 is confusing.
General FAAC compiling instructions
1. Make sure you have recent versions of autoconf, automake and libtool installed.
For MP4 writing and tagging support, you must enable compiling with internal libmp4v2 (included in /common/mp4v2/).
2. cd to FAAC source dir
3. Run:
./configure
make
make install
Michael Rampe
on Sep 30, 2011 at 2:16:20 am
[C David Young] "The audio sounds ok but the image is missing."
You need the -map command for two inputs.
Michael
C David Young
on Sep 30, 2011 at 6:34:05 pm
I tried putting "-map 0:v" after the video input and it made no difference. I also put "-map 0:a" after the audio input and it said there was no such stream. However, I am having some success as follows. Now to see if I can append the individual slides, each of which will be an mp4 file.
I can convert the 3gp audio to aac with the following:
ffmpeg -y -i IMAG001.3gp -ab 128k -ar 48k -ac 2 -strict experimental -acodec aac IMAG001.aac
When I add the video the resulting mp4 plays the audio with the image.
ffmpeg -y -f image2 -r .2 -i IMAG001.jpg -i IMAG001.aac -s 720x480 IMAG001.mp4
