converting series of images to a video slideshow
COW Forums : FFmpeg
C David Young
on Sep 22, 2011 at 5:43:26 pm
I wish to convert a series of images (.jpg) to a video slideshow where I can specify how long each image is displayed. In addition I would like to add narration to each image as well as specify a music track. The output should be compatible with youtube/facebook. Can anyone suggest an ffmpeg command line to accomplish this? I have been playing around with the documented technique (ffmpeg -f image2 -i foo-%03d.jpeg -r 12 -s WxH foo.avi) but am not having much luck.
Thanks in advance.
Michael Rampe
Re: converting series of images to a video slideshow
on Sep 22, 2011 at 8:41:12 pm
[C David Young] "(ffmpeg -f image2 -i foo-%03d.jpeg -r 12 -s WxH foo.avi) but am not having much luck."
What is going wrong?
Michael
C David Young
on Sep 22, 2011 at 9:17:24 pm
Well, for one thing it only seems to be adding the first image, which only shows up briefly when playing in VLC. If I set the frame rate really low (-r .1) the image shows longer but I don't think that is the right technique. So I guess the first hurdle is to figure out why only the first image is showing up. The output below seems to indicate that only the first image is being processed.
C:Androidffmpeg for windowsffmpeg-git-a254452-win32-staticbin>ffmpeg -y -f image2 -i IMAG-%03d.jpg -s 720x480 a.mp4
ffmpeg version N-32726-ga254452, Copyright (c) 2000-2011 the FFmpeg developers
built on Sep 19 2011 19:49:13 with gcc 4.6.1
configuration: --enable-gpl --enable-version3 --enable-runtime-cpudetect --enable-avisynth --enable-bzlib --enable-frei0r --enable-libopencore-amrnb
libavutil 51. 16. 1 / 51. 16. 1
libavcodec 53. 16. 0 / 53. 16. 0
libavformat 53. 12. 0 / 53. 12. 0
libavdevice 53. 4. 0 / 53. 4. 0
libavfilter 2. 43. 2 / 2. 43. 2
libswscale 2. 1. 0 / 2. 1. 0
libpostproc 51. 2. 0 / 51. 2. 0
Input #0, image2, from 'IMAG-%03d.jpg':
Duration: 00:00:00.28, start: 0.000000, bitrate: N/A
Stream #0.0: Video: mjpeg, yuvj420p, 3264x1952, 25 fps, 25 tbr, 25 tbn, 25 tbc
[buffer @ 024C5FE0] w:3264 h:1952 pixfmt:yuvj420p tb:1/1000000 sar:0/1 sws_param:
[scale @ 024C5060] w:3264 h:1952 fmt:yuvj420p -> w:720 h:480 fmt:yuvj420p flags:0x4
[libx264 @ 02511A60] using cpu capabilities: MMX2 SSE2Fast SSSE3 Cache64
[libx264 @ 02511A60] profile High, level 3.0
[libx264 @ 02511A60] 264 - core 116 r2074 2641b9e - H.264/MPEG-4 AVC codec - Copyleft 2003-2011 - http://www.videolan.org/x264.html - options: cabac=1
eightp=2 keyint=250 keyint_min=25 scenecut=40 intra_refresh=0 rc_lookahead=40 rc=crf mbtree=1 crf=23.0 qcomp=0.60 qpmin=0 qpmax=69 qpstep=4 ip_ratio=1
Output #0, mp4, to 'a.mp4':
Metadata:
encoder : Lavf53.12.0
Stream #0.0: Video: h264 (![0][0][0] / 0x0021), yuvj420p, 720x480, q=-1--1, 25 tbn, 25 tbc
Stream mapping:
Stream #0.0 -> #0.0 (mjpeg -> libx264)
Press [q] to stop, [?] for help
frame= 7 fps= 0 q=-1.0 Lsize= 84kB time=00:00:00.20 bitrate=3451.2kbits/s
video:83kB audio:0kB global headers:0kB muxing overhead 1.000866%
frame I:1 Avg QP:25.84 size: 16625
[libx264 @ 02511A60] frame P:6 Avg QP:26.97 size: 11349
[libx264 @ 02511A60] mb I I16..4: 15.7% 59.7% 24.6%
[libx264 @ 02511A60] mb P I16..4: 12.1% 54.0% 16.5% P16..4: 1.3% 0.2% 0.2% 0.0% 0.0% skip:15.8%
[libx264 @ 02511A60] 8x8 transform intra:64.4% inter:84.1%
[libx264 @ 02511A60] coded y,uvDC,uvAC intra: 60.8% 70.7% 30.0% inter: 3.1% 5.7% 0.1%
[libx264 @ 02511A60] i16 v,h,dc,p: 35% 14% 3% 48%
[libx264 @ 02511A60] i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 22% 14% 14% 7% 8% 8% 8% 9% 9%
[libx264 @ 02511A60] i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 27% 18% 13% 7% 9% 8% 7% 6% 4%
[libx264 @ 02511A60] i8c dc,h,v,p: 50% 17% 23% 10%
[libx264 @ 02511A60] Weighted P-Frames: Y:0.0% UV:0.0%
[libx264 @ 02511A60] ref P L0: 69.4% 5.4% 11.1% 14.1%
[libx264 @ 02511A60] kb/s:2420.51
C David Young
on Sep 22, 2011 at 9:32:58 pm
As I read more about ffmpeg I figure my best approach might be to create a separate video file of the correct duration for each image muxed with the narration, and then concatenate the files while muxing the music. Does that make any sense?
Michael Rampe
on Sep 22, 2011 at 9:35:23 pm
[C David Young] "Well, for one thing it only seems to be adding the first image,"
Are your images are *definitely* named IMAG-001.jpg. IMAG-002.jpg, IMAG-003.jpg ...etc?
I tired your line with a series of images named this way and it works.... so not sure otherwise....
Michael
C David Young
on Sep 22, 2011 at 10:29:04 pm
Yes, that is how my image files are named.
What does your output look like? Does it dwell for a second or two on each image? What OS are you running? Which player are you using?
Michael Rampe
on Sep 22, 2011 at 10:45:35 pm
[C David Young] "What does your output look like? Does it dwell for a second or two on each image? What OS are you running? Which player are you using?
OK. I dug a little further....
I split a movie into files for testing and then reassembled with your code.
When I tried to change the frame rate, I got the same bug as you.
I fixed this by putting the -r 1 BEFORE the input.
Now I get one frame playing per second.
$ ffmpeg -y -f image2 -r 1 -i test-%03d.jpg -s 720x480 a.mp4
FYI: OSX 10.7, QT/VLC
Michael
C David Young
on Sep 23, 2011 at 11:05:19 am
Wow. With the following line (-r .2) I was able to get each image to show for 5 seconds. Thanks!
$ ffmpeg -y -f image2 -r .2 -i test-%03d.jpg -s 720x480 a.mp4
Now regarding the audio clips that I want to play in synchronization with the images, is there a similar command for muxing the audio files (.3gp) with this a.mp4? Or should I mux the audio files with the images first to create a series of .mp4 files and then concatenate them?
