What is the transcoding unit for FFMPEG
COW Forums : FFmpeg
atish kathpal
on Sep 12, 2011 at 4:48:01 am
Hi friends
What is the transcoding unit for FFMEG? Is it a file or can we transcode a single file as user defined chunks of equal/variable size?
Eg: Given a video: Austral.mpeg (10mins). Can I divide it into 10 chunks of 1 min each while transcoding, such that each 1min chunk is accessible once transcoding for it is over?
Thanks and regards.
Michael Rampe
Re: What is the transcoding unit for FFMPEG
on Sep 22, 2011 at 8:15:00 pm
[atish kathpal] " can we transcode a single file as user defined chunks of equal/variable size?"
yes but you will have to run one command for each chunk.
-t is a time offset
specified seconds or hh:mm:ss[.xxx]
-ss is the length to encode
This option behaves differently if put before or after the -i [input]
Before:seeks to nearest I frame before converting (fast but inaccurate)
After:seeks through every frame until target is reached (slow but accurate)
So:
first chunk: -t 0 -ss 60
second chunk: -t 60 -ss 60
third chunk: -t 120 -ss 60
.....etc.
Michael
