FFmpeg behaves differently
COW Forums : FFmpeg
Vinod Aravind
on Aug 17, 2011 at 8:16:57 am
Please see these files in FLV:
1) http://selectaplumber.com/files/local.flv
2) http://selectaplumber.com/files/lunar.flv
These are the output flv files converted from local and lunarhost (By using ffmpeg command line in PHP and source file is an mpeg4). But you can see that the lunar.flv is not showing progress bar, but local.flv shows it.
I use the command ffmpeg -i $inputfilename $outputfilename. Please advice.
Regards,
Vinod
Michael Rampe
Re: FFmpeg behaves differently
on Aug 27, 2011 at 12:32:29 am
not sure....
can you run an input read on both and post the results?
$ ffmpeg -i yourfile.flv
Michael
