Batch merge 50 audio tracks with corresponding video tracks using FFmpeg.
COW Forums : FFmpeg
Freddie Hill
on Aug 8, 2011 at 3:56:14 pm
Is there any way to batch merge 50 audio tracks with corresponding video tracks without re-encoding, using FFmpeg?
I have run into an instance where I have to do this and wondered if it's able to be done in a 'batch' procedure. I know you can do this using QT pro but you have to merge everything singularly.
Any advice on this would be great.
Freddie
Michael Rampe
Re: Batch merge 50 audio tracks with corresponding video tracks using FFmpeg.
on Aug 27, 2011 at 12:35:29 am
[Freddie Hill] "Is there any way to batch merge 50 audio tracks with corresponding video tracks without re-encoding, using FFmpeg?"
yep. Write a shell script with a 'while' or 'for' loop to run through them all.
Use -acodec copy -vcodec copy to not recompress.
Michael
