stream to jpeg
COW Forums : FFmpeg
nayan kapadia
stream to jpeg
on Jun 3, 2010 at 5:19:53 am
HI,
I have converted image from live stream using ffmpeg -i rtsp:///main.mp4 -an -r 1 -y -s 320x240 video%d.jpg.Using this I obtain continous jpeg images. Is there any way to generate only one image and overwrite that image after each frame using ffmpeg?
Another thing,I am using ffmpeg on windows.When i type ffmpeg.exe in command line it displays ffmpeg version message and configuration message, how can i stop display of these messages on command line?
Thank you,
NBK
Michael Rampe
Re: stream to jpeg
on Jun 3, 2010 at 5:40:35 am
[nayan kapadia] "Is there any way to generate only one image and overwrite that image after each frame using ffmpeg?"
Do not use the "%d" in the image name. This is what creates sequential image numbers.
The "-y" flag will overwrite the previous image which you are using. Try putting it just before the output filename.
Eg.
ffmpeg -i rtsp:///main.mp4 -an -r 1 -s 320x240 -y video.jpg
This might work or might just create one frame and stop. Not too sure about this. Try it and see.
[nayan kapadia] "When i type ffmpeg.exe in command line it displays ffmpeg version message and configuration message, how can i stop display of these messages on command line?"
You cannot stop this display.
Michael
"half-way to world domination A.K.A. the belligerent blue bike shed"
Michael Rampe
Re: stream to jpeg
on Jun 3, 2010 at 6:09:29 am
Just tried to replicate it and it didn't work. Just wrote one frame and failed.
I will keep looking into it.
What is the intended purpose for this process? There might be a workaround if I know what you are trying to achieve.
Michael
nayan kapadia
Re: stream to jpeg
on Jun 3, 2010 at 10:27:16 am
Thanks for your reply. I can generate image only once not able to update image.
Thank you,
NBK
Michael Rampe
Re: stream to jpeg
on Jun 3, 2010 at 11:57:55 pm
Yes, it fails after one frame.
What are you trying to achieve?
Michael
nayan kapadia
Re: stream to jpeg
on Jun 4, 2010 at 9:06:12 am
I want to update and overwrite image from live stream continously and want to display in server.
NBK
Michael Rampe
Re: stream to jpeg
on Jun 7, 2010 at 7:18:41 am
I cannot think of a way to do what you need within FFmpeg but it could be easily solved writing a shell script.
The command that produces the single frame takes less than a second on my setup. Seeing that you have specified the rate to be 1fps for pulling the frames, you could write a script that calls the same command from FFmpeg every second overwriting the previous frame and thus producing the desired result.
Michael
