-vcodec copy -acodec copy
COW Forums : FFmpeg
richie bee
on Jun 23, 2011 at 7:41:51 pm
Hi I was using -vcodec libx264 with -sameq
and found the files were doubling in size
so tried -vcodec copy
and all fine and so quick to convert!
is there any reason why I shouldn't use -vcodec copy?
Michael Rampe
Re: -vcodec copy -acodec copy
on Jul 4, 2011 at 10:57:51 pm
[richie bee] "is there any reason why I shouldn't use -vcodec copy?"
Depends on what you are doing.
If you are just repacking the stream into a different container or splitting the audio from the video, -vcodec copy is the right choice as it does exactly what you would expect, copy the stream without re-encoding.
If you are changing bitrate, size, aspect or applying filters, this is not a good choice.
Michael
richie bee
on Jul 5, 2011 at 9:04:07 am
thanks
