ffmpeg ffv1 lossless question-
COW Forums : FFmpeg
Ryan Smith
on May 12, 2011 at 11:48:47 pm
I am attempting to encode a tif sequence using ffv1 lossless compression. Upon encoding to FFV1 and decoding back to TIF, my image is not identical.
I am able to encode fine using the following command:
ffmpeg -f image2 -i c:/LTTemp/%03d.tif -vcodec ffv1 out2.avi
I can then take that avi file and extract it back into a tif sequence using the following:
ffmpeg -i out2.avi c:/LTTemp/2/image%d.tif
I get a warning that my original tif image is PAL8 and will be converted to YUV420P which I believe to be my problem, however I am stuck on how to remedy this. My input image type is a 2D unsigned char tif written to disk using ITK. Thanks in advance-
© 2018 All Rights Reserved
