ffmeg write text on a video
COW Forums : FFmpeg
jefferson Goven
on May 3, 2011 at 2:35:08 pm
Hello i installed ffmeg with the drawtext option, I do:
ffmpeg -i file.mov -vf drawtext="fontfile=/usr/share/fonts/truetype/ttf-dejavu/DejaVuSerif.ttf:text='Text to write':fontsize=20:fontcolor=black:x=100:y=100" final.mov
it works but i would like to make the text appear at a specific time around 3 or 5 sec after the video start
Michael Rampe
Re: ffmeg write text on a video
on May 5, 2011 at 12:27:20 am
[jefferson Goven] "Hello i installed ffmeg with the drawtext option, I do:
ffmpeg -i file.mov -vf drawtext="fontfile=/usr/share/fonts/truetype/ttf-dejavu/DejaVuSerif.ttf:text='Text to write':fontsize=20:fontcolor=black:x=100:y=100" final.mov"
I recompiled and tried this and it works well. Last time I tried it had several issues. One feature I am looking for is "centre justified" text which seems not to be an option. Any ideas?
[jefferson Goven] "it works but i would like to make the text appear at a specific time around 3 or 5 sec after the video start
No ideas specifically using libavfilter..... I will have a look into it. A workaround would be to generate an overlay "movie" first with alpha with text that doesn't start until this time. Of course, this would not be using the drawtext filter but the overlay filter........ I will keep thinking.
Michael
Basavaraju Gandla
on Dec 17, 2013 at 8:12:39 am
Hi Michael,
I have been working on the same issue.
I was trying to add text while capturing.
Do I have to do it before encoding or after encoding ?
Can you please suggest me the right way to overlay text on video file through program rather than pipelines.
Thank you,
Regards,
Baz
jefferson Goven
on Dec 17, 2013 at 6:51:16 pm
I did it before encoding for me because i had to merge multiple sounds and videos after.
Basavaraju Gandla
on Dec 18, 2013 at 7:16:10 am
Hi jefferson Goven,
I am really glad for your reply.
Can you please send me the example code, How you have done it.
Thanking you,
Regards,
Basavaraju Gandla
Ashish Tondak
on Oct 20, 2015 at 7:05:36 am
ffmpeg -y -i backdrop.mp4 -vf drawtext="text='Test sdafsdafasdfadsfdsf':enable='between(t,3,8)':fontfile='/usr/share/fonts/truetype/freefont/FreeSerif.ttf':fontsize=20:fontcolor=red:x=100:y=100" -t 10 -acodec copy hmmm9999999.mp4
