4CIF H263 video fails to decode
COW Forums : FFmpeg
Ankuj Gupta
on Apr 8, 2011 at 3:45:42 am
I am trying to decode a H263 4CIF(704x576) resolution file with ffmpeg, but it is detected as mp3 file and fails to get decoded. I tried with lower resolution H263 files they get decoded easily. I am using ffmpeg version 0.6.1
Michael Rampe
Re: 4CIF H263 video fails to decode
on Apr 9, 2011 at 10:09:25 pm
[Ankuj Gupta] "I am trying to decode a H263 4CIF(704x576) resolution file with ffmpeg, but it is detected as mp3 file and fails to get decoded. I tried with lower resolution H263 files they get decoded easily. I am using ffmpeg version 0.6.1"
I created a file to replicate your issue and it decoded properly:
Stream #0.0(eng): Video: h263, yuv420p, 704x576 [PAR 12:11 DAR 4:3], 780 kb/s, 25 fps, 25 tbr, 25 tbn, 29.97 tbc
Can you give me some more information. What container are you using, framerate and can you post the ffmpeg command line and output?
Michael
Ankuj Gupta
on Apr 13, 2011 at 3:38:57 am
Hi Michael
The command I am giving is
ffmpeg -i h263_704x576_15fps_3370kbps.263 4cif.yuv
The untrimmed output of the command is
FFmpeg version 0.6.1, Copyright (c) 2000-2010 the FFmpeg developers
built on Apr 8 2011 14:08:35 with gcc 4.1.2 20080704 (Red Hat 4.1.2-46)
configuration: --disable-demuxer=v4l --disable-demuxer=v4l2 --disable-indevs
libavutil 50.15. 1 / 50.15. 1
libavcodec 52.72. 2 / 52.72. 2
libavformat 52.64. 2 / 52.64. 2
libavdevice 52. 2. 0 / 52. 2. 0
libswscale 0.11. 0 / 0.11. 0
Inside fn av_probe_input_format2(), first_iformat=b61680, score_max=70f9163c
Returning from fn av_probe_input_format2() fmt=0, score_max=70f9163c, scor=0
No. of chunks = 512
Inside fn av_probe_input_format2(), first_iformat=b61680, score_max=70f911bc
Returning from fn av_probe_input_format2() fmt=0, score_max=70f911bc, scor=0
Returning from fn av_probe_input_format2() fmt=b60360, score_max=70f911bc, scor=0
[NULL @ 0x5115420]Format detected only with low score of 24, misdetection possible!
[mp3 @ 0x51166d0]Header missing
Last message repeated 17 times
[mp3 @ 0x51166d0]big_values too big
[mp3 @ 0x5115420]max_analyze_duration reached
[mp3 @ 0x5115420]Estimating duration from bitrate, this may be inaccurate
Input #0, mp3, from 'h263_704x576_15fps_3370kbps.263':
Duration: 01:45:31.25, start: 0.000000, bitrate: 96 kb/s
Stream #0.0: Audio: mp2, 44100 Hz, 2 channels, s16, 96 kb/s
Output #0, rawvideo, to '4cif.yuv':
Output file #0 does not contain any stream
bitrate is 3370kbps
frame rate is 15fps
It is Video elementary stream of H263
Michael Rampe
on Apr 27, 2011 at 4:43:32 am
[Ankuj Gupta] "[NULL @ 0x5115420]Format detected only with low score of 24, misdetection possible!"
This shows that it cannot determine the format itself.
Have you tried to force the format by putting -f h263 BEFORE the -i flag?
Michael
