ffserver + mplayer
COW Forums : FFmpeg
Giorgio Ascani
ffserver + mplayer
on Mar 2, 2011 at 7:49:11 pm
I'm trying to use ffmpeg / ffserver to create a RTSP server.
What I do is:
$./ffserver -f ffserver.conf
with the following ffserver.conf:
#Port on which the server is listening. You must select a different
# port from your standard HTTP web server if it is running on the same
# computer.
Port 8091
# RTSP Port
RTSPPort 7654
# Address on which the server is bound. Only useful if you have
# several network interfaces.
BindAddress 0.0.0.0
# Port on which the server is listening. You must select a different
# computer.
RTSPBindAddress 0.0.0.0
# Number of simultaneous requests that can be handled. Since FFServer
# is very fast, it is more likely that you will want to leave this high
# and use MaxBandwidth, below.
MaxClients 1000
# This the maximum amount of kbit/sec that you are prepared to
# consume when streaming to clients.
MaxBandwidth 1000
# Access log file (uses standard Apache log file format)
# '-' is the standard output.
CustomLog -
# Suppress that if you want to launch ffserver as a daemon.
NoDaemon
Format rtp
File "/home/marco/Videos/11.mpg"
Format rtp
File "/home/marco/Videos/12.mpg"
Format rtp
File "/home/marco/Videos/13.mpg"
And I get:
marco@marco-virtual-machine:~/Documents/ffmpeg/ffmpeg-0.6.1aaaa$ ./ffserver -f ffserver.conf
FFserver version 0.6.1, Copyright (c) 2000-2010 the FFmpeg developers
built on Mar 2 2011 11:53:56 with gcc 4.4.5
configuration:
libavutil 50.15. 1 / 50.15. 1
libavcodec 52.72. 2 / 52.72. 2
libavformat 52.64. 2 / 52.64. 2
libavdevice 52. 2. 0 / 52. 2. 0
libswscale 0.11. 0 / 0.11. 0
Wed Mar 2 17:53:42 2011 Opening file '/home/marco/Videos/11.mpg'
Wed Mar 2 17:53:43 2011 [mpeg @ 0x92a9720]max_analyze_duration reached
Wed Mar 2 17:53:43 2011 Opening file '/home/marco/Videos/12.mpg'
Wed Mar 2 17:53:43 2011 Opening file '/home/marco/Videos/13.mpg'
Wed Mar 2 17:53:43 2011 FFserver started.
Then i try to play the video with mplayer:
$mplayer rtsp://localhost:7654/11.mpg
The problem is that mplayer show:
MPlayer 1.0rc4-4.4.5 (C) 2000-2010 MPlayer Team
mplayer: could not connect to socket
mplayer: No such file or directory
Failed to open LIRC support. You will not be able to use your remote control.
Playing rtsp://localhost:7654/11.mpg.
Resolving localhost for AF_INET6...
Connecting to server localhost[::1]: 7654...
connect error: Connection refused
Resolving localhost for AF_INET...
Connecting to server localhost[127.0.0.1]: 7654...
A single media stream only is supported atm.
rtsp_session: unsupported RTSP server. Server type is 'unknown'.
STREAM_LIVE555, URL: rtsp://localhost:7654/11.mpg
Stream not seekable!
file format detected.
Initiated "video/MPV" RTP subsession on port 47150
Initiated "audio/MPA" RTP subsession on port 42762
Exiting... (End of file)
and the ffserver show:
Wed Mar 2 17:55:55 2011 127.0.0.1 - - [DESCRIBE] "rtsp://localhost:7654/11.mpg RTSP/1.0" 200 449
Wed Mar 2 17:55:55 2011 [mpeg @ 0x92b74c0]max_analyze_duration reached
Wed Mar 2 17:55:55 2011 127.0.0.1:47150 - - "PLAY 11.mpg/streamid=0 RTP/UDP"
Wed Mar 2 17:55:55 2011 127.0.0.1:42762 - - "PLAY 11.mpg/streamid=1 RTP/UDP"
Wed Mar 2 17:55:55 2011 127.0.0.1 - - [TEARDOWN] "rtsp://localhost:7654/11.mpg/ RTSP/1.0" 200 864
Whats wrong?!?!?!?!?
thank you in advance
Giorgio
