Webm Error
COW Forums : FFmpeg
Kit Carrau
Webm Error
on Jan 27, 2011 at 11:11:25 am
I am trying to convert video files to the webm format. I am using
FFmpeg and have installed the libvpx library. I can confirm this when
I run the following:
$ ./ffmpeg -formats 2> /dev/null | grep WebM
E webm WebM file format
$ ./ffmpeg -codecs 2> /dev/null | grep libvpx
DEV libvpx libvpx VP8
Which means I should be able to convert to webm? However when I run
"ffmpeg -i [input.mp4] [output.webm]", I get the following error:
"Encoder (codec id 146) not found for output stream #0.0"
Has anyone got any ideas?
Many Thanks,
Kit
Michael Rampe
Re: Webm Error
on Jan 27, 2011 at 8:56:06 pm
[Kit Carrau] "Which means I should be able to convert to webm? However when I run
"Encoder (codec id 146) not found for output stream #0.0""
Have you tried specifying the codec rather than relying on FFmpeg choosing based on output container?
Example: -vcodec libvpx -b 1500k
Michael
