FFmpeg and the QuickTime PhotoJPEG codec
COW Forums : FFmpeg
Dave Navarro
on Apr 14, 2010 at 8:09:53 am
When you encode a .MOV file in QuickTime using the PhotoJPEG codec you get a slider that gives you a "percentage" of compression.
Typically when delivering clips to clients who require PhotoJPEG I use "80%" as my base (I increase it if it causes issues).
In attempts and using FFmpeg to encode to PhotoJPEG I have not yet found an equivalent formula/method for obtaining the same results. I spent a solid day one weekend comparing encoded files with different commands line settings and various files encoded using QuickTime Pro and couldn't come up with anything consistent across different types of clips (animation, DV footage, hi res HD footage, etc..).
Has anyone else experimented with this or do you know of a way to encode a file at "80% PhotoJPEG" using FFmpeg that gets similar results to QuickTime Pro?
Michael Rampe
Re: FFmpeg and the QuickTime PhotoJPEG codec
on Apr 14, 2010 at 8:38:52 am
[Dave Navarro] "I spent a solid day one weekend comparing encoded files with different commands line settings and various files encoded using QuickTime Pro"
Can you give me some examples of command lines you were trying?
Michael
"half-way to world domination A.K.A. the belligerent blue bike shed"
