Convert png sequence to Quicktime ProRes 422.
COW Forums : FFmpeg
Jeremy Eliosoff
on Feb 17, 2017 at 4:50:33 am
Hello,
I'm trying to convert an image sequence of .png's into a Quicktime movie in ProRes 422 format on Linux. I am submitting this to a film festival and it is crucial that it be in EXACTLY this format. I have been using ffmpeg like so (note the film is 10 frames per second):
ffmpeg -start_number 0 -f image2 -r 10 -i image.%04d.png -i ~/Desktop/aud/aud_01.wav -codec:v prores -profile:v NUMBER -r 10 -strict -2 final.mov
I've tried various options for NUMBER following -profile:v, then checked the resulting video codec by using the "Properties" function in Linux's totem media player. Here are the results I get:
0 = Apple ProRes Proxy
1 = Apple ProRes LT
2 = Apple ProRes
3 = Apple ProRes HQ
Are any of these ProRes 422? I've already submitted option 3, Apple ProRes HQ, and the festival is not yet sure they can accept it. Is there something else I should be doing?
Thank you,
Jeremy.
Gyan Doshi
Re: Convert png sequence to Quicktime ProRes 422.
on Feb 17, 2017 at 12:17:11 pm
The default encoder reports only supporting YUV 4:2:2 10-bit output, so it should be that. Run ffprobe final.mov or ffmpeg -i final.mov to check.
Jeremy Eliosoff
on Feb 17, 2017 at 1:49:50 pm
Thank you very much for the quick response. To confirm, you're saying all of the movies created from the above commands should indeed be in ProRes422 format? Here is the output of ffprobe for two of the resulting movies. Note that in both cases it says encoder : Lavc56.60.100 prores.
Using -profile:v 2:
~/Desktop/v09shortEnd:ffprobe testV2.mov
ffprobe version 2.8.11-0ubuntu0.16.04.1 Copyright (c) 2007-2017 the FFmpeg developers
built with gcc 5.4.0 (Ubuntu 5.4.0-6ubuntu1~16.04.4) 20160609
configuration: --prefix=/usr --extra-version=0ubuntu0.16.04.1 --build-suffix=-ffmpeg --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu --cc=cc --cxx=g++ --enable-gpl --enable-shared --disable-stripping --disable-decoder=libopenjpeg --disable-decoder=libschroedinger --enable-avresample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libmodplug --enable-libmp3lame --enable-libopenjpeg --enable-libopus --enable-libpulse --enable-librtmp --enable-libschroedinger --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxvid --enable-libzvbi --enable-openal --enable-opengl --enable-x11grab --enable-libdc1394 --enable-libiec61883 --enable-libzmq --enable-frei0r --enable-libx264 --enable-libopencv
libavutil 54. 31.100 / 54. 31.100
libavcodec 56. 60.100 / 56. 60.100
libavformat 56. 40.101 / 56. 40.101
libavdevice 56. 4.100 / 56. 4.100
libavfilter 5. 40.101 / 5. 40.101
libavresample 2. 1. 0 / 2. 1. 0
libswscale 3. 1.101 / 3. 1.101
libswresample 1. 2.101 / 1. 2.101
libpostproc 53. 3.100 / 53. 3.100
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'testV2.mov':
Metadata:
major_brand : qt
minor_version : 512
compatible_brands: qt
encoder : Lavf56.40.101
Duration: 00:01:59.00, start: 0.023220, bitrate: 38311 kb/s
Stream #0:0(eng): Video: prores (apcn / 0x6E637061), yuv422p10le, 1920x1080, 38193 kb/s, 10 fps, 10 tbr, 10240 tbn, 10240 tbc (default)
Metadata:
handler_name : DataHandler
Stream #0:1(eng): Audio: aac (LC) (mp4a / 0x6134706D), 44100 Hz, stereo, fltp, 126 kb/s (default)
Metadata:
Using -profile:v 3:
~/Desktop/v09shortEnd:ffprobe testV3.mov
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'testV3.mov':
Metadata:
major_brand : qt
minor_version : 512
Duration: 00:01:59.00, start: 0.023220, bitrate: 55753 kb/s
Stream #0:0(eng): Video: prores (apch / 0x68637061), yuv422p10le, 1920x1080, 55634 kb/s, 10 fps, 10 tbr, 10240 tbn, 10240 tbc (default)
Metadata:
Metadata:
Gyan Doshi
on Feb 17, 2017 at 2:12:50 pm
Yeah. The pixel format is identified by the string yuv422p10le which is YUV 4:2:2 (planar, 10 bits per channel stored in little-endian order).
Jeremy Eliosoff
on Feb 19, 2017 at 4:06:21 am
Thank you very much for your help!
