Sound drift when streaming
COW Forums : FFmpeg
nadav talmor
on Jan 8, 2017 at 9:08:19 am
Hello
I am streaming rtmp with ffmpeg from a camera source that delivers 50fps frame rate to a matrox capture card.
until recently I have been using "vMix" in order to capture the video and release it via dshow to ffmpeg.
among other things, the "vMix" was taking the frame rate and changing it to 25fps before reaching to ffmpeg.
due to some circumstances, I tried to avoid using "vMix" and start capturing the video straight to ffmpeg from the card. in order to deal with the frame rate, I have added the command -r 25 to the ffmpeg command.
from this point on the sound has gotten out of sync while the audio was coming first.
In order to deal with that I add the commands "-async" and "-itsoffset" which corrected the initial sync issues.
The problem is that with time (the stream is 24/7) the sound is drifting further away from video to the point that after 20 hours it has a 2 sec delay, when audio is coming before video.
This is my current command:
ffmpeg.exe -async 2 -report -rtbufsize 256M -f dshow -i "video=Matrox A/V Input" -itsoffset 0.250 -f dshow -i "audio=Matrox A/V Input" -codec:v libx264 -r 25 -tune fastdecode -tune zerolatency -s:v 1280x720 -pix_fmt:v yuv420p -threads 4 -bufsize:v 1000k -g:v 50 -preset:v ultrafast -profile:v Main -level:v 3.0 -b:v 2500k -maxrate:v 2700k -flush_packets 1 -codec:a libfaac -b:a 64k -strict -2 -map 0:v -map 1:a -rtmp_flashver "FMLE/3.0 (compatible; vMix/15.0.0.74)" -f flv rtmp url -codec:v libx264 -s:v 854x480 -pix_fmt:v yuv420p -threads 0 -bufsize:v 500k -g:v 24 -bf 2 -preset:v veryfast -profile:v Main -level:v 3.1 -b:v 500k -minrate:v 500k -maxrate:v 500k -codec:a libfaac -b:a 64k -strict -2 -map 0:v -map 1:a -rtmp_flashver "FMLE/3.0 (compatible; vMix/15.0.0.74)" -f segment -strftime 1 -segment_list out.list -segment_time 60 -segment_wrap 24 -segment_time_delta 0.02 E:\Share\Video\out_%%d-%%m-%%y_%%H-%%M-%%S.mp4
the report looks like this:
ffmpeg started on 2017-01-02 at 12:48:29
Report written to "E:\Share\LivePBT\Logs\test\1.12\ffmpeg_NadavTest2_out_20170102-124829.log"
Command line:
"c:\\LivePBT\\Streaming\\test\\NadavTest2\\ffmpegNadavTest2.exe" -async 2 -report -rtbufsize 256M -f dshow -i "video=Matrox A/V Input" -itsoffset 0.250 -f dshow -i "audio=Matrox A/V Input" -codec:v libx264 -r 25 -tune fastdecode -tune zerolatency -s:v 1280x720 -pix_fmt:v yuv420p -threads 4 -bufsize:v 1000k -g:v 50 -preset:v ultrafast -profile:v Main -level:v 3.0 -b:v 2500k -maxrate:v 2700k -flush_packets 1 -codec:a libfaac -b:a 64k -strict -2 -map 0:v -map 1:a -rtmp_flashver "FMLE/3.0 (compatible; vMix/15.0.0.74)" -f flv rtmp url -codec:v libx264 -s:v 854x480 -pix_fmt:v yuv420p -threads 0 -bufsize:v 500k -g:v 24 -bf 2 -preset:v veryfast -profile:v Main -level:v 3.1 -b:v 500k -minrate:v 500k -maxrate:v 500k -codec:a libfaac -b:a 64k -strict -2 -map 0:v -map 1:a -rtmp_flashver "FMLE/3.0 (compatible; vMix/15.0.0.74)" -f segment -strftime 1 -segment_list out.list -segment_time 60 -segment_wrap 24 -segment_time_delta 0.02 "E:\\Share\\Video\\out_%d-%m-%y_%H-%M-%S.mp4"
ffmpeg version 2.5.git Copyright (c) 2000-2015 the FFmpeg developers
built on Jan 8 2015 02:08:21 with Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 16.00.40219.01 for 80x86
configuration: --enable-gpl --enable-version3 --enable-libx264 --toolchain=msvc --enable-zlib --enable-libfaac --enable-nonfree
libavutil 54. 16.100 / 54. 16.100
libavcodec 56. 19.100 / 56. 19.100
libavformat 56. 18.100 / 56. 18.100
libavdevice 56. 3.100 / 56. 3.100
libavfilter 5. 6.100 / 5. 6.100
libswscale 3. 1.101 / 3. 1.101
libswresample 1. 1.100 / 1. 1.100
libpostproc 53. 3.100 / 53. 3.100
Input #0, dshow, from 'video=Matrox A/V Input':
Duration: N/A, start: 525121.924000, bitrate: N/A
Stream #0:0: Video: rawvideo (YUY2 / 0x32595559), yuyv422, 1280x720, 50 tbr, 10000k tbn, 50 tbc
Guessed Channel Layout for Input Stream #1.0 : stereo
Input #1, dshow, from 'audio=Matrox A/V Input':
Duration: N/A, start: 525121.937000, bitrate: 1411 kb/s
Stream #1:0: Audio: pcm_s16le, 44100 Hz, 2 channels, s16, 1411 kb/s
[tcp @ 004DF360] TCP Buffer has been set to 1048576 bytes
-async is forwarded to lavfi similarly to -af aresample=async=2:min_hard_comp=0.100000:first_pts=0.
[libx264 @ 004D5F40] frame MB size (80x45) > level limit (1620)
[libx264 @ 004D5F40] MB rate (90000) > level limit (40500)
[libx264 @ 004D5F40] using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX FMA3 AVX2 LZCNT BMI2
[libx264 @ 004D5F40] profile Constrained Baseline, level 3.0
[libx264 @ 004D5F40] 264 - core 144 - H.264/MPEG-4 AVC codec - Copyleft 2003-2014 -urll - options: cabac=0 ref=1 deblock=0:0:0 analyse=0:0 me=dia subme=0 psy=1 psy_rd=1.00:0.00 mixed_ref=0 me_range=16 chroma_me=1 trellis=0 8x8dct=0 cqm=0 deadzone=21,11 fast_pskip=1 chroma_qp_offset=0 threads=4 lookahead_threads=4 sliced_threads=1 slices=4 nr=0 decimate=1 interlaced=0 bluray_compat=0 constrained_intra=0 bframes=0 weightp=0 keyint=50 keyint_min=5 scenecut=0 intra_refresh=0 rc_lookahead=0 rc=abr mbtree=0 bitrate=2500 ratetol=1.0 qcomp=0.60 qpmin=0 qpmax=69 qpstep=4 vbv_maxrate=2700 vbv_bufsize=1000 nal_hrd=none filler=0 ip_ratio=1.40 aq=0
[libx264 @ 004D6F60] using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX FMA3 AVX2 LZCNT BMI2
[libx264 @ 004D6F60] profile Main, level 3.1
[libx264 @ 004D6F60] 264 - core 144 - H.264/MPEG-4 AVC codec - Copyleft 2003-2014 - url - options: cabac=1 ref=1 deblock=1:0:0 analyse=0x1:0x111 me=hex subme=2 psy=1 psy_rd=1.00:0.00 mixed_ref=0 me_range=16 chroma_me=1 trellis=0 8x8dct=0 cqm=0 deadzone=21,11 fast_pskip=1 chroma_qp_offset=0 threads=12 lookahead_threads=3 sliced_threads=0 nr=0 decimate=1 interlaced=0 bluray_compat=0 constrained_intra=0 bframes=2 b_pyramid=2 b_adapt=1 b_bias=0 direct=1 weightb=1 open_gop=0 weightp=1 keyint=24 keyint_min=2 scenecut=40 intra_refresh=0 rc_lookahead=10 rc=cbr mbtree=1 bitrate=500 ratetol=1.0 qcomp=0.60 qpmin=0 qpmax=69 qpstep=4 vbv_maxrate=500 vbv_bufsize=500 nal_hrd=none filler=0 ip_ratio=1.40 aq=1:1.00
Output #0, flv, to 'url:
Metadata:
encoder : Lavf56.18.100
Stream #0:0: Video: h264 (libx264) ([7][0][0][0] / 0x0007), yuv420p, 1280x720, q=-1--1, 2500 kb/s, 25 fps, 1k tbn, 25 tbc
Metadata:
encoder : Lavc56.19.100 libx264
Stream #0:1: Audio: aac (libfaac) ([10][0][0][0] / 0x000A), 44100 Hz, stereo, s16, 64 kb/s
Metadata:
encoder : Lavc56.19.100 libfaac
Output #1, segment, to 'E:\Share\Video\out_%d-%m-%y_%H-%M-%S.mp4':
Metadata:
Stream #1:0: Video: h264 (libx264), yuv420p, 854x480, q=-1--1, 500 kb/s, 50 fps, 12800 tbn, 50 tbc
Metadata:
Stream #1:1: Audio: aac (libfaac), 44100 Hz, stereo, s16, 64 kb/s
Metadata:
Stream mapping:
Stream #0:0 -> #0:0 (rawvideo (native) -> h264 (libx264))
Stream #1:0 -> #0:1 (pcm_s16le (native) -> aac (libfaac))
Stream #0:0 -> #1:0 (rawvideo (native) -> h264 (libx264))
Stream #1:0 -> #1:1 (pcm_s16le (native) -> aac (libfaac))
Press [q] to stop, [?] for help
The capture card is Matrox Mojito max and the pc is HP Z440 with windows 7.
What did I do wrong, or, what else can I try?
Thank you
Reuben Martin
Re: Sound drift when streaming
on Apr 9, 2017 at 3:39:01 am
What is the source of the audio? I find it odd that the sample rate that ffmpeg is getting from the source is at 44100. That would suggest that the audio is not embedded in the camera video source. If that's the case you may be suffering from clock drift due to separate audio / video devices running off of separate clocks.
nadav talmor
on Apr 9, 2017 at 8:53:43 am
Hi Reuben Martin
Thanks for your reply.
The sound comes from a mic connected to a mixer/preamp that is connected back to the camera before capture card.
From the SDI capture card the sound does not drift, but only after encoding the stream.
BR,
Reuben Martin
on Apr 10, 2017 at 1:56:16 am
Where then is the audio getting re-sampled to 44100? Embedded SDI audio is at 48k.
nadav talmor
on May 15, 2017 at 12:03:03 pm
By a preamp mixer.
