Encoding 4:4:4 in h264/h265
COW Forums : FFmpeg
Jonas Jensen
on Dec 1, 2016 at 2:05:46 pm
I've been trying for a while now to find a good solution for making high-quality video files, for local playback, to display detailed motion graphics. Basically I end up with problems everywhere because of the sampling rate. Almost all available formats will deliver in 4:2:2 which is not good enough for my purposes.
So as I understand it, 4:4:4 encoding should be possible in H264, but I can't find a solution for doing it.
Will FFmpeg do it? And if so, could someone point me in the direction of the correct command?
Icaro Lobo
Re: Encoding 4:4:4 in h264/h265
on Dec 13, 2016 at 11:36:36 pm
I was looking for the same thing and tried several ffmpeg GUI. The only one I could render 4:4:4 h264 was myffmpeg.
Icaro Lobo
on Dec 13, 2016 at 11:40:38 pm
Also this:
But it is command-line.
Chris Oram
on Dec 22, 2016 at 2:43:51 pm
the x264 profile command for this in ffmpeg is fairly straight forward to implement off of CLI - it is;
-profile:v high444
You will of course need to set your bit rates max/min and presets as desired but this profile setting will output a h.264 at 4:4:4.
-Chris Oram
http://antiversal.com
Technology, Design and Development for Moving Image Creators
