How to stream 2 webcams through FFMPEG on VB.NET
COW Forums : FFmpeg
qweqwe dasd
on Aug 30, 2014 at 6:02:56 am
I like to stream 2 webcams from ffmpeg on windows to Flash media server in RTMP protocol.
I use FFMPEG to stream videos in a background by ProcessStartInfo , now I have a problem to use 2 FFMPEG to stream 2 webcams the same time.
When I run first FFMPEG it is run successfuly and it streams webcam1 correctly on the Media Server, when I want to start webcam2 to stream, the second ffmpegs in not runing.
This is my codes to start each FFMPEG:
Dim psi As ProcessStartInfo = New ProcessStartInfo("c:\ffmpeg.exe")
Dim proc As Process = Process.Start(psi)
psi.UseShellExecute = False
psi.CreateNoWindow = True
psi.Arguments = " -f dshow -i video=""USB Camera"" -threads 1 -preset ultrafast -vcodec libx264 -b:v 640k -acodec copy -f flv rtmp:// "
proc = Process.Start(psi)
Please advise me to fix this problem
your help will be appreciated
© 2018 All Rights Reserved
