ffmpeg -map audio option
COW Forums : FFmpeg
Kevin Wells
on Apr 8, 2014 at 9:26:14 am
Hi, I am trying to export all audio channels from a quicktime file which has the following audio configuration:
Track 1 - mono
Track 2 - mono
Track 3 - mono
Track 4 - mono
Track 5 - mono
Track 6 - mono
Track 7 - stereo
I am using:
ffmpeg -i Feature.mov -map 0:1 -y Left.wav -map 0:2 Right.wav -map 0:3 Center.wav -map 0:4 LFE.wav -map 0:5 Left_Surround.wav -map 0:6 Right_Surround.wav -map 0.7 L+R_Total.wav
But this is giving me an error. So I want to output 6 mono wavs and 1 stereo wav.
How do I do that?
Kind regards.
stephen dixon
Re: ffmpeg -map audio option
on Apr 9, 2014 at 2:11:37 pm
Stream numbering starts at 0. Check with ffprobe to make sure you're using the right specifier for each stream.
Also, post the error.
Stephen Dixon
Editor, Animator, Motionographer
Museum Victoria
