FFmpeg 0.60 Problem - unsupported codec
COW Forums : FFmpeg
tom pepe
on Jul 30, 2010 at 7:53:45 am
Hello,
i've got a strange problem with ffmpeg. Im trying to extend my Software with a small Videoplayer-feature. What i have to do is just to open a videofile and read the images. I only need the videodata of a video, because its a computer vision application.
So i found a website which descibes how to do this. (http://dranger.com/ffmpeg/tutorial01.html)
I use ffmpeg 0.60 for this application, which I've downloaded from the ffmpeg website.
I've builded ffmpeg with the following configurations:
./configure --enable-gpl --enable-swscale --enable-nonfree
After make and make install I've copied the lib and headerfiles to my Projectdirectory. (It's a Qt-Project)
Here is the sourcecode i use to open a videofile (Its just the code from the tutorial):
int FFmpegHandler::openVideoStream(QString fileName)
AVFormatContext *pFormatCtx;
int i, videoStream;
AVCodecContext *pCodecCtx;
AVCodec *pCodec;
AVFrame *pFrame;
AVFrame *pFrameRGB;
AVPacket packet;
int frameFinished;
int numBytes;
uint8_t *buffer;
// Register all formats and codecs
av_register_all();
// Open video file
if(av_open_input_file(&pFormatCtx, fileName.toLatin1(), NULL, 0, NULL)!=0)
return -1; // Couldn't open file
// Retrieve stream information
if(av_find_stream_info(pFormatCtx)<0)
return -1; // Couldn't find stream information
// Dump information about file onto standard error
dump_format(pFormatCtx, 0, fileName.toLatin1(), false);
// Find the first video stream
videoStream=-1;
for(i=0; inb_streams; i++)
if(pFormatCtx->streams[i]->codec->codec_type==CODEC_TYPE_VIDEO)
videoStream=i;
break;
if(videoStream==-1)
return -1; // Didn't find a video stream
// Get a pointer to the codec context for the video stream
pCodecCtx=pFormatCtx->streams[videoStream]->codec;
// Find the decoder for the video stream
pCodec=avcodec_find_decoder(pCodecCtx->codec_id);
if(pCodec==NULL)
fprintf(stderr, "Unsupported codec!n");
return -1; // Codec not found
return 0;
So when im running my application it always outputs in the console:
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/home/pollok/Desktop/out-7.mp4':
Duration: 00:00:35.00, start: 0.000000, bitrate: 451 kb/s
Stream #0.0(und): Video: mpeg4, yuv420p, 320x240 [PAR 1:1 DAR 4:3], 15,00 tb(r)
Stream #0.1(und): Audio: libfaad, 48000 Hz, stereo
Unsupported codec!
But when I use ffplay to display the video it works without prolems... What am I doing wrong? I need help urgent, because I'm trying to programm that since one week.
FFplay outputs the following: (This is an older Version of ffmpeg, which was already preinstalled on my Linux)
FFplay version SVN-r13582, Copyright (c) 2003-2008 Fabrice Bellard, et al.
configuration: --prefix=/usr --libdir=${prefix}/lib --shlibdir=${prefix}/lib --bindir=${prefix}/bin --incdir=${prefix}/include/ffmpeg --enable-shared --enable-libmp3lame --enable-gpl --enable-libfaad --mandir=${prefix}/share/man --enable-libvorbis --enable-pthreads --enable-libfaac --enable-libxvid --enable-postproc --enable-libamr-nb --enable-libamr-wb --enable-x11grab --enable-libgsm --enable-libx264 --enable-liba52 --enable-libtheora --extra-cflags=-Wall -g -fPIC -DPIC --cc=ccache cc --enable-swscale --enable-libdc1394 --enable-nonfree --disable-mmx --disable-stripping --enable-avfilter --enable-libdirac --disable-decoder=libdirac --enable-libschroedinger --disable-encoder=libschroedinger --disable-altivec --disable-armv5te --disable-armv6 --disable-vis
libavutil version: 49.7.0
libavcodec version: 51.58.0
libavformat version: 52.16.0
libavdevice version: 52.0.0
libavfilter version: 0.0.0
built on May 3 2009 12:02:42, gcc: 4.3.2
My lib version, which i have compiled is:
libavcodec.52.72.2
libavdevice.52.2.0
libavfilter.1.19.0
libavformat.52.64.2
libavutil.50.15.1
libpostproc.51.2.0
libswscale.0.11.0
Can anybody help me? Im thankful for every idea.
Nice regards,
Tom
Michael Rampe
Re: FFmpeg 0.60 Problem - unsupported codec
on Aug 3, 2010 at 5:28:07 am
[tom pepe] "I've builded ffmpeg with the following configurations:
./configure --enable-gpl --enable-swscale --enable-nonfree"
You have not installed or enabled the libfaad or libfaac libraries. This is why it is reporting:
[tom pepe] "Unsupported codec!"
Your ffplay does have these libraries installed and configured. This is why it works in FFplay but not FFmpeg.
add --enable-libfaad and --enable-libfaac to your FFmpeg configure line.
Michael
"half-way to world domination A.K.A. the belligerent blue bike shed"
tom pepe
on Aug 3, 2010 at 9:34:48 am
[Michael Rampe]You have not installed or enabled the libfaad or libfaac libraries. This is why it is reporting:
[Michael Rampe]Your ffplay does have these libraries installed and configured. This is why it works in FFplay but not FFmpeg.
But when you have a look at the sourcecode:
if(pCodec==NULL)
libfaad and libfaac are en- and decoder for audiostreams.
But I never access to the audio channel - only to the video channel.
So why should this be the solution for my problem?
Nice Regards,
Tom
PS: Thanks for your reply.
Michael Rampe
on Aug 3, 2010 at 11:57:06 pm
It appears that there is an audio stream in your input. Unless FFmpeg is told to ignore the audio (using -an for example on the command line), it will pass the stream through to the output. That is why I think you are having the problem of unsupported codec.
Michael
