wrapping to MXF
COW Forums : FFmpeg
Borko Grujic
wrapping to MXF
on Oct 9, 2013 at 8:22:04 am
Hi everyone,
Local TV now insists on MXF (MPEG2 long GOP, MXF OPT1A or B, PAL, 4:2:2, 12Mbps, Audio WAV/PCM)
So I am totally fine with creating mpeg like this... how do I wrap it in MXF? (would prefer to do it on mac)
B
Lou Logan
Re: wrapping to MXF
on Oct 9, 2013 at 8:33:54 pm
If you simply need to re-mux with stream copy mode:
$ ffmpeg -i input -codec copy -map 0 output.mxf
If you need to re-encode:
$ ffmpeg -i input -c:v mpeg2video -b:v 12M -pix_fmt yuv422p -c:a pcm_s16le -map 0 output.mxf
Should result in OP-1a. Note that, depending on your input, you may have to declare additional options such as an output frame rate with "-r" (or the fps video filter). Default GOP size will be 12, I believe, but this can be changed with the "-g" option.
For encoder capabilities/restrictions and a list of private options see:
$ ffmpeg -h encoder=mpeg2video
