MPEG4 to H.264 conversion
COW Forums : FFmpeg
nayan kapadia
on Mar 18, 2010 at 11:13:28 am
I want to convert MPEG4(part 2) file into H.264 video file. Can someone has any idea/ sample code to do this.
thank you,
NBK
Michael Rampe
Re: MPEG4 to H.264 conversion
on Mar 18, 2010 at 7:37:05 pm
ffmpeg -i input.mp4 -vcodec libx264 -vpre libx264-hq -b 1500k output.mp4
This will create a H.264 stream in a mp4 wrapper at 1500 kbps. It will be at the original image size as -s was not specified.
You will need libx264 installed and enabled for this line to work. libx264 produces H.264 streams and is highly recommended.
nayan kapadia
on Mar 19, 2010 at 3:05:38 am
Thank you for your reply. I want to do MP4 to H.264 conversion using C program in ffmpeg. Do you have any idea/sample code for that?
Thank you,
Nayan Kapadia
Michael Rampe
on Mar 19, 2010 at 4:15:38 am
Not too sure about what you mean by "C program".
Do you mean writing a program in C++ that uses ffmpeg or simply running ffmpeg in the command line?
